Windows 10 - 2 problems on fresh system
Discussion in 'Desktop Hardware' started by sew333, Jan 20, 2018.
  1. sew333
    sew333 Notebook Geek
    My pc:
    8700K stock
    2x8GB DDR4 GSKILL 3000mhz ( XMP
    Corsair 750 i
    Asus Z370 Pro Gaming.
    I have 2 disks. SSD Crucial 525 GB MX 300 and Toshiba 500GB.
    I have an question about system Windows 10.
    I installed from Pendrive USB Windows 10 from here:
    https://www.microsoft.com/en-us/software-download/windows10
    On a fresh formatted ssd i install Windows 10.
    When i installed Windows 10 there was a problem with...
    1.When i go to windows settings, no matter what i click on system settings it wont opened. SO click and nothing.
    2.Problem with web browsers ( Firefox and Chrome ).
    When i go to some site, and try to download something ( right click save ), browser just hang,and not respond. I had to click X on the browser.
    This happens in BOTH Firefox and Chrome, which is why I think it's an issue on Windows' part?
    That was this 2 problems after i installed Windows 10 from Pendrive.
    I dont know how but after 2-3 restart now its all fine and working fine.
    I just ask why that happened? It maybe was related to my rams?
    But i tested memtests and no errors. Thanks for suggestions.
    I also checked DISK status, and GOOD HEALTHS.
  2. KY_BULLET
    KY_BULLET Notebook Evangelist
    Thats wierd, did Windows update install any updates during the restarts that may have fixed the problem?
  3. sew333
    Yes i think something was updated .
    KY_BULLET likes this.
  4. StormJumper
    StormJumper Notebook Virtuoso
    Sounds like a corrupted install from the read of it. Did you install it offline or connected to internet? And did you install all the board drivers first before connecting to internet? Never have it connected to the internet when you install so there nothing being downloaded or interference before you get all the drivers updated.
  5. sew333
    I tried to reproduce issue and formatted 2 times ssd, and installed 2 times Windows 10 on fresh. But this not happened again. So propably hardware is fine or not?
  6. sew333
    Hello. My cpu 8700K ,16GD DDR GSKILL XMP ( 3000mhz )
    2 disks: SSD Crucial 525 GB MX300, HDD TOSHIBA 500GB 7200RP
    I downloaded from microsoft Windows 10 and make bootable iso in Pendrive Kingston Data Traveler.
    During install i format SSD and HDD. I choose to install Windows 10 to SSD.
    After installed Windows 10
    I faced this issue:
    http://www.surfacetablethelp.com/20...rvice-in-windows-10-fall-creators-update.html
    My Windows 10 computer has became slow after cleaned install of Fall Creators. When I load some website in Edge and click on any link, nothing happens and the browser keeps freezing. I notice that state repository service takes about 100% resources of CPU usage. It happens while I connect it to internet via ethernet network. Then I open the Immersive control panel or Settings app and click on any link, the same problem appears, no matter using Microsoft or local account.
    After 2-3 restarts issue gone. But i tried to reproduce this issue and i format disk again and installed Win 10 again from pendrive. But this time all was fine.
    And my question is. Why after second format and second clean install Windows 10 i dont had this issue? Thank you for explanation. Cheers
    From what i read from internet problem is reproducable. I met peoples that they reproduce issue by each fresh install on formatted partition. So why i cant?
