win32 startup trojan help !!!!!!!!!!!!
Discussion in 'Security and Anti-Virus Software' started by jerryw618, Apr 10, 2010.
  1. jerryw618
    jerryw618 Newbie
    ok so several programs have detected win32startup trojan , but i cant get it cleaned out ? file mfplay.dll is locked or something i cant delete it? any ideas?
  2. flipfire
    flipfire Moderately Boss
    Which programs are you using?
    Its probably locked because its in use by the virus.
    Deleting a .dll can be risky. Confirm that its a virus first
  3. jerryw618
    jerryw618 Newbie
    well pest patrol confirmed it says it will delete it at reboot but warning keeps popping up , and file still there. i have pest patrol , avg antivirus, spybot search and destroy,easycleaner, programs
    but i cant gt rid of this pest
  4. MrDJ
    MrDJ Notebook Nobel Laureate
    is it the free avg your using. if so delete it and try another free antivirus like avast or microsoft security essentials as not all are the same and sometimes miss or give of a false positive.
  5. jerryw618
    jerryw618 Newbie
    hi no its a paid full version of avg. ive just downloaded several free av's avira eset and microsoft security ill try em all out till i get this cleaned any other suggestions ? searches for win32 startup all take you to sites that want you to buy their av stuff
  6. Baserk
    Baserk Notebook user
    Have you tried the free versions of Malwarebytes'Antimalware and HitmanPro?
    Can you upload the dll to VirusTotal or Jotti's Malware Scan to confirm it's not a false positive?
  7. jerryw618
    jerryw618 Newbie
    not yet will check them oyt though thanks , ill post results soon thanks
  8. MrDJ
    dont forget to turn off your paid for avg before using any others as they will clash.
    also download Spybot Search & Destroy which is a great free bit of kit.
  9. jerryw618
    jerryw618 Newbie
    well i tried all this stuff posted and not one alerts too it just pest patrol ? so how do i deal with this do i just ignore it in pest patrol since nothing else sees it as a threat ???????
  10. gerryf19
    gerryf19 I am the walrus
    http://www.file.net/process/mfplay.dll.html
    according to that, mfplay.dll is part of a Browser Helper Object--the reason it cannot be deleted is that it loads with IE--and since IE is so tightly integrated into Windows, it essentially loads with Windows.
    It is likely part of a toolbar. You can probably uninstall it by removing all toolbars in add/remove control panel applet.
