will VGA to 22 inch monitor look good?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by bpage, Feb 11, 2009.
  1. jakejm79
    jakejm79 Notebook Consultant
    RE: Windows7, I have been using it and other than some crashes in games (and even those were pretty much limited to one game and the graphics settings test). Other than that my only issue has been with mapping a network drive, it never seems to reconnect at logon or save the password.
  2. bpage
    bpage Notebook Enthusiast
    i am able to get a copy of windows 7 32bit through my school for free.. would you recommend the 32bit version or should I just hold on to the 64bit vista that comes with my laptop? i'm not entirely sure of the differences between the 2 bit versions
  3. jakejm79
    I am unsure of what you mean, "through my school for free" since it's being beta tested and is free to everyone available to sign up. I would suggest you keep both and dual boot since come summer 09 W7 should stop working if it's the beta. Plus it would allow you to compare side by side.
  4. bpage
    i guess you right.. im an idiot lol.. i thought you could only get the beta through torrents and stuff.. where could i find a link for the 64bit version of windows 7?
  5. jakejm79
  6. Tippey764
    Tippey764 Notebook Deity
    I have done 1920 x 1200 with an ati radeon 9000igp lol
  7. bpage
    it says that downloads are no longer being offered for it.. will it go up again?
  8. Colton
    Colton Also Proudly American
    Back to the original question, I am running a full HD 22inch monitor via VGA, and looks great. It's just as good as my brother's DVI connection on a monitor that's almost the same as mine.
  9. sublime313
    sublime313 Notebook Evangelist
    ok i went out and bought a 6' HDMI 1.3b cable today for $27 and guess what? i dont notice ANY difference than from the VGA connection. absolutely zero! i think i might take it back for a refund... ???
    i'll also add that my monitor is 24" 1920x1080 and i have the reslution set as such...
  10. bpage
    colton, cam you get 720p resolution with vga? i wasnt sure if you could get any hd if you go through vga..
