Will it be possible for the 15inch 2.2 MBP to have a Thunderbol eGPU??
Discussion in 'e-GPU (External Graphics) Discussion' started by Karant-rex, Jul 9, 2011.
  1. KernalPanic
    KernalPanic White Knight
    Given the fact MUCH more powerful cards with no hybrid at all and no consideration for battery life at all are getting 3-4, its pretty much expected.
  2. Karamazovmm
    Karamazovmm Overthinking? Always!
    Its not apple to allow, but us to code something, people on the windows world face some difficulties sometimes doing the egpu thing
    actually no, windows machines pack that same gpu, or nvidia similars, only achieve that battery life with extended batteries and switchable gpus.
    its is really a shame that customizations or actual engineering like what happens on business machines is not applied to those cases, so yeah its pitful at best to have the same battery life as machines that uses some form of switching
    now on the thread, I havent been able to identify what ports are wired to the thunderbolt port, however there is one good news, even my mbp 13 posses a mux in the gpu... so we may be able to wire the thunderbolt port to display the image on the notebook lcd, no external monitors required
  3. ryzeki
    ryzeki Notebook Prophet
    Of course it does, because Express card is barely 1x of PCIe. If it where 1 lane of PCIe v3.x, the Express card slot would have almost the same bandwidth as thunderbolt. It is far much better to get an Express card slot with actual 4x or more lanes, which would give significantly more bandwidth than thunderbolt.
    10-20Gb/s is not that much, considering typical current PCIe speeds roam about 64Gb/s for the old v2.0 PCIe. v3.x is even higher. It is a lot, however, when compared to the rest of ports (USB etc) available on PC.
    It's a nice port with high memory bandwidth compared to many other ports available in PC, but for graphics card, its far easier(and faster) to make a higher lane count express card for an eGPU.
  4. Karamazovmm
    well according to some reviews, x4 is an acceptable bandwidth, most games suffer a penalty of 1-10%, being some ports the cause of high consumption of bandwidth and where staggering differences where felt, something around 50%
    I did some tests right now, and nothing is conclusive as of yet, but it seems that the pcie ports that the thunderbolt is going to use are the ports 4-8, thus raising the possibility that all are sequential.
  5. User Retired 2
    Found a Macbook Pro 8.2's lspci output here.
    What they've done is split the x16 root port into two x8 ports (0:1.0 and 0:1.1). The first has all 8 lanes connected and is used to host the dGPU (HD6750M). The second is the Thunderbolt port with only 4 of the 8 lanes connected as highlighted below. So Thunderbolt is x4 2.0 as I expected it to be.
    Code:
    00:01.1 PCI bridge [0604]: Intel Corporation 2nd Generation Core Processor Family PCI Express Root Port [8086:0105] (rev 09) (prog-if 00 [Normal decode])
    	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    	Latency: 0, Cache Line Size: 256 bytes
    	Bus: primary=00, secondary=05, subordinate=9b, sec-latency=0
    	I/O behind bridge: 00004000-00004fff
    	Memory behind bridge: b0a00000-b4efffff
    	Prefetchable memory behind bridge: 00000000b4f00000-00000000b8efffff
    	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
    	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
    		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    	Capabilities: [88] Subsystem: Apple Computer Inc. Device [106b:00dc]
    	Capabilities: [80] Power Management version 3
    		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
    		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
    	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
    		Address: feeff00c  Data: 4159
    	Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
    		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
    			ExtTag- RBE+ FLReset-
    		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
    			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
    			MaxPayload 128 bytes, MaxReadReq 128 bytes
    		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
    		LnkCap:	Port #3, Speed 5GT/s, Width x8, ASPM L0s L1, Latency L0 <256ns, L1 <4us
    			ClockPM- Surprise- LLActRep- BwNot+
    		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled+ Retrain- CommClk+
    			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
    		LnkSta:	[COLOR="Red"][B]Speed 5GT/s, Width x4[/B][/COLOR], TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt-
    		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
    			Slot #2, PowerLimit 75.000W; Interlock- NoCompl+
    		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
    			Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
    		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
    			Changed: MRL- PresDet+ LinkState-
    		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
    		RootCap: CRSVisible-
    		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
    		DevCap2: Completion Timeout: Not Supported, TimeoutDis- ARIFwd-
    		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- ARIFwd-
    		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -3.5dB
    			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
    			 Compliance De-emphasis: -6dB
    		LnkSta2: Current De-emphasis Level: -3.5dB
    	Capabilities: [100 v1] Virtual Channel
    		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
    		Arb:	Fixed- WRR32- WRR64- WRR128-
    		Ctrl:	ArbSelect=Fixed
    		Status:	InProgress-
    		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
    			Arb:	Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
    			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
    			Status:	NegoPending- InProgress-
    	Capabilities: [140 v1] Root Complex Link
    		Desc:	PortNumber=03 ComponentID=01 EltType=Config
    		Link0:	Desc:	TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
    			Addr:	00000000fed19000
    	Kernel driver in use: pcieport
    	Kernel modules: shpchp
  6. funky monk
    funky monk Notebook Deity
    If you're worrying about bandwidth, you should probably watch these videos.
    <param name="movie" value="http://www.youtube.com/v/NFMzRZqFh-w?version=3&amp;hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/NFMzRZqFh-w?version=3&amp;hl=en_GB" type="application/x-shockwave-flash" width='640' height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    <param name="movie" value="http://www.youtube.com/v/rSfifE2Domo?version=3&amp;hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/rSfifE2Domo?version=3&amp;hl=en_GB" type="application/x-shockwave-flash" width='640' height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
