Will a repaste with kyronaut help my notebook when creating videos?
Discussion in 'Dell' started by kojack, Mar 13, 2021.
  1. kojack
    kojack Notebook Virtuoso
    I posted here about my notebook stressing hard while editing videos. If I repaste with Kryonaut, will it help it power through a bit better. It does it, but not without the fans complaining ALOT. Thoughts on this?
  2. custom90gt
    It may help it run cooler and maintain higher clocks, but it likely won't be the end all be all solution so to speak. The fans will still ramp up to max speeds unless you modify their RPM. It's worth a shot, but you've read my XPS postings about trying to get every last ounce of performance from a laptop (getting what you paid for). Your best bang for the buck would be undervolting though, but that takes some time/effort.
    Let us know if you have issues with the repaste, it's not too bad once you've done a couple.
    Spartan@HIDevolution and kojack like this.
  3. kojack
    I have done some repastes on desktops in the past. I am just trying to make my notebook survive being pushed like that. If a repaste will help and make sure it can handle being cooked like that while I am on the road working, I will be fine. I am under no dilusion that my notebook will do anything fast, as long as it can do it. I don't mind waiting for a couple of hours while a video encodes etc. I can sit down, enjoy the scenery, maybe take more pictures, or drink a few icy beverages!
    custom90gt likes this.
  4. Spartan@HIDevolution
    and out of all the good thermal pastes in the world, you choose the worst which has the least longevity? Watch your temps start rising within 7 days of applying Kyronaut.
    http://forum.notebookreview.com/threads/thermal-grizzly-kryonaut.790919/page-10#post-10261106
    http://forum.notebookreview.com/thr...s-before-i-start.741745/page-65#post-10249996
    http://forum.notebookreview.com/thr...iquid-metal-paste.812596/page-2#post-10660500
    PHOBYA NanoGrease Extreme FTW but it's out of stock everywhere now so the next best is GELID GC Extreme Thermal Compound or Arctic MX-4
    kojack and saturnotaku like this.
  5. saturnotaku
    Kryonaut is bad for laptop use because it has a tendency to break down at temperatures above 80C. I’ve had great luck with Gelid GC Extreme. It’s not terribly expensive and easy to apply.
    kojack and Spartan@HIDevolution like this.
  6. kojack
    I wasn't looking at longevity, thanks' for pointing that out. I will probably go with MX-4 as I can get it locally. Thanks for the heads up.
  7. Spartan@HIDevolution
    Anytime my friend! MX-4 lasts slightly longer than GELID GC Extreme too!
    kojack likes this.
  8. custom90gt
    Ehh, wife's repaste from >3 years ago is still running strong with Kryonaut, as are the countless other laptops I've repasted with it.
  9. Spartan@HIDevolution
    custom90gt and kojack like this.
