Wifi Catcher
Discussion in 'Dell XPS and Studio XPS' started by thomasshiow, Jul 23, 2008.
  1. thomasshiow
    thomasshiow Notebook Geek
    Umm what does the wifi catcher thing do on my XPS 1530? Pressing it does absolutely nothing?
  2. rubenvb
    rubenvb Notebook Consultant
    When your laptop is turned of, you can hold the switch thingie and a led will let (pun not intended) you know if there's a wireless network in range without turning on the laptop... pretty useless if you ask me but hey... who am i?
  3. thomasshiow
    haha oh so thats what it does..sigh..i use hspda 3G most of the time anyway
  4. jhawk
    jhawk Notebook Guru
    I had the same problem. Found tha unless you have Dell's quickset running the WiFi catcher won't work. Make sure the quickset starts at startup and you shouldn't have any problems.
  5. Forte
    Forte NBR's Supreme Angel
    Yeah, personally I think its a useless feature since it picks up every wireless connection secure or unsecured. If you could change the settings so that it picked up only the non-secured free wifi... it would make it much more useful.
  6. paper_wastage
    paper_wastage Beat this 7x7x7 Cube
    i havent played enough with my laptop yet, but sometimes the orange light comes on, sometimes the blue light comes on(the light that's next to the catcher button)....
    think i need to read the manual
  7. thomasshiow
    Well never successfully used the wifi catcher function before, usually use my wifi enabled phone to check for hot spots.
