WiFi card in WWAN slot doesn't work
Discussion in 'Alienware M11x' started by vorob, Jul 3, 2016.
  1. vorob
    vorob Notebook Deity
  2. vorob
  3. kosti
    kosti Notebook Virtuoso
    This should clear it up for you. Look at the diagram labeled "USB Only Mini PCIe"
    http://electronics.stackexchange.co...format-with-usb-host-interface-what-does-this
    It is basically wired to the USB bus and not to the PCI Express bus. Most WLAN cards will not work here, some may. I had a netbook with a similar slot and found a specific WLAN card that worked but it was a specific model made to interface with USB only mini PCIe slots. On my M11X I use mine with the adapter below for my mouse's receiver.
    deadsmiley and vorob like this.
  4. supperchym
    supperchym Newbie
    For me it's working. U can see 2 wifi card in my screenshot (M11x r2)
