Wifi card antenna clips?
Discussion in '2015+ Alienware 13 / 15 / 17' started by cope123abc, Feb 14, 2020.
  1. cope123abc
    cope123abc Notebook Evangelist
    Guys,
    What's the clips for the 17 r4 wifi card, I think it's a 8265, I have a damaged one on the laptop.
    It's the gold part that clips onto the wifi card
    Thanks all
  2. MogRules
    MogRules Notebook Deity
    If it's broken off inside the antenna cable then you will need to fish it out with a pair of tweezers or a pin and replace the WiFi card.
    I think this might be the first instance of this happening on an Intel card I have seen. It happens constantly on the older Killer models though.
  3. cope123abc
    It was on a laptop i bought, somebody had sheered off the 2 little golden connectors , the wifi card is intact :(
    From reading i needed a NGFF clip connector
  4. CptXabaras
    CptXabaras Overclocked, Overvolted, Liquid Cooled
    If i understood your problem (pictures are worth a thousand words...) you don't need a NGFF connector but rather an MHF-4 mini coaxial connector (ex: https://www.i-pex.com/product/mhf-4)
    The NGFF connector type is the slot like connector where the Wifi card is connected to
    NGFF: (this is not the connector you are looking for. Read it Obi-Wan style)
    MHF-4:
    jeremyshaw likes this.
  5. cope123abc
    thanks buddy your a star !
    CptXabaras likes this.
