Widcomm 5 Bluetooth Software for Sony SZ
Discussion in 'VAIO / Sony' started by BlackG35, Mar 7, 2006.
  1. BlackG35
    BlackG35 Notebook Consultant
    I got Widcomm 5 working on my SZ160!!! :D
    I had to modify the drivers to support the internal Bluetooth device on Sony SZ series notebooks.
    I've been comparing the Widcomm software to the Toshiba software.
    Some advantages I found with Widcomm over the Toshiba:
    - You can synchronize your phonebook, calender and etc, on your cell phone with Microsoft Outlook.
    - You can also view and copy files on your phone in shell mode.
    - You can set-up virtual serial ports to use bluetooth in certain applications.
    - Some of these features are phone dependent and work with my Sony W800i phone.
    ________________________________________
    Download Widcomm 5 software: click here
    Download modified Sony SZ Bluetooth drivers: click here
    1) Uninstall all previous Toshiba Bluetooth software.
    2) Turn off the bluetooth device using VAIO wireless utility.
    2) Run and install Widcomm setup.
    It will say Bluetooth device not found, click cancel to continue installation.
    3) Now turn on Bluetooth using VAIO wireless utility. It should detect new hardware and ask you to install the device.
    Click install from a specific location.
    Select the folder you unzipped the modified drivers to:
    Widcomm should now recognize the internal bluetooth device.
    Widcomm 5
  2. jacksonn298
    jacksonn298 Notebook Guru
    Hi there, is the Widcomm 5 better than the one that comes with the laptop? Sorry I'm new to this bluetooth stuff. Thanks
  3. mkraft
    mkraft Newbie
    You links don't work. Any chance you can host the files elsewhere?
    Mark
  4. BlackG35
    Its a much more versitile and compatible bluetooth software.
    I just bought a logitech bluetooth v270 mouse and its was only supported by widcomm software.
    I didnt use the toshiba software much, but I believe this program has more services available.
  5. BlackG35
    They work for me... :confused:
  6. ostack
    ostack Notebook Evangelist
    Looks like you may have to register an account there to access the files.
  7. Bossy573
    Bossy573 Notebook Consultant
    I just bought the same mouse and it would not load the logitech software. However, I did get the mouse connected using the Sony software and it works just fine.
  8. Mark²
    Mark² Notebook Guru
    That's weird, since the exact same v270 mouse worked immediately with my SZ 160's bluetooth. Hmmm...
    Here's a question: Why aren't there any bluetooth mice with side "back" buttons?? They are ALL only two buttons plus a wheel! What gives? Is this a limitation due to the nature of Blutooth?
  9. ostack
    Logitech MX1000
    It has side back-forward-app switcher, scroll-wheel w/left-right, up/down rocker, rechargable, and laser. Mine came with wireless desktop set.
  10. avicenne13
    avicenne13 Notebook Geek
    There is :cool:
    Try the Microsoft Bluetooth mouse...
