why is there no battery dock for clevo top line models?
Discussion in 'Sager and Clevo' started by amirbahalegharn, Apr 7, 2018.
if there is a battery dock available which gives you +7 extra hours usage,would you buy it ?
  1. yes
  2. no
Results are only viewable after voting.
  1. amirbahalegharn
    amirbahalegharn Notebook Guru
    why is there no clevo laptop with decent battery life(more than 6 hours) just like gigabyte aero/XPS and ...
    and why they don't add/make/sell a Battery dock like those hp ones which stick to bottom and get us 6 to 9 hours usage with especially gaming/workstations/supercomputers(p751/p755/p870/w650kj/p65XX for current models) ones . who doesn't need more gaming + regular usage on-time without being worry about the battery. if they can't install a bigger battery,ok, at least give us a decent battery dock to buy & go with... and I am still waiting for dual CPU + dual GPU in 18inch made by clevo with bezel-less design monitor and a premabios preinstalled or at least make stock better and same-wise bios.
    another suggestion: for p75X/p7XX/P8XX series,as there is no thickness limit,why not make a whole new battery,completely covering bottom with ..this way, the motherboard could be bigger(for 2nd cpu {they may even make a dual socket type motherboard for 1st time in industry,one am4,one lg1151) or even make space for another fan or sth else they could come up with
  2. Paul16
    Paul16 Notebook Enthusiast
    +1
    I’m tired of hearing that this are “gaming” laptops.
    I am 3d graphics artist working in a cinema industry and i often work somewhere in the fields without proper dc inputs. And all this gaming laptops are perfect for me to work on the go. But they dont last long. So i have to order separate dc generator
    joluke and slimmolG like this.
  3. TheReciever
    TheReciever D! For Dragon!
    Because its illegal to sell more than 97wh in the US and also your already in a niche market that many consider for some reason is dying off.
    bennyg likes this.
  4. Meaker@Sager
    To get an hour of full load would take a 200-330Wh battery which as above gets pretty awkward.
    You are better off with a machine that targets a lower load level and will be more efficient at the 90w mark.
  5. 1610ftw
    1610ftw Notebook Enthusiast
    Just offer a dual boot mode that some of the MSI units have.
    And maximize the batteries to the biggest legal size in addition to make them removable so that one can always bring a spare battery, an option to add an external battery pack would also be welcome.
    Agreed on a bigger than 17" small bezel solution. I would like something that is sized like the MSI GT8x units but with a normal keyboard and a 19.5 to 20" 16:10 2560x1600 screen option - that would be a terrific workstation and gaming laptop. Not sure how much of a market is out there for such a device but I am sure that by making something as big as the GT83 but less ugly, with a proper LGA CPU and a bigger screen one would get more customers and not less.
    Unfortunately even if manufacturers recognize a certain demand they have an issue with no proper screens being available for such beasts. There seem to be very few screen options once one goes beyond 17" and even at 17" the available 2560 x 1440 screen option has lower contrast and a smaller color space than most Full HD and UHD screen options.
  6. Meaker@Sager
    No one makes larger panels and if they do they are behind the standard units in quality, features and price.
    16:10 died years ago.
    Removable batteries are lower capacity for the same size usually.
  7. Paul16
    Clevo laptops have interchangeable battery. And i can buy some spares. But I didn’t see any external laptop battery charges.
    Like chargers for cordless power tools
  8. Paul16
    Hm. My idea suddenly turned to @kickstartercampaign
  9. amirbahalegharn
    if its a restriction,is it for one device or just one battery? if its in one battery , then again they can use 2-3 batteries of 97Wh just covering below entire surface!(so that by removing battery you get to motherboard & if they insist on doing old fashion,then the same bottom regular cover.
    they can use the same space on the same surface level of motherboard for another fan(they may use new fan model like vacuume ones this way in the empty section to avoid the heating and channeling it towards the side,rather than the user belly) to change hot air flowing from bottom to sides.
    it wouldn't be that difficult to use such structure/design and achieve 2 purpose(high usage time/better efficiency in heat management) at once
    if its laptop,and workstation on top of that,it should be portable(and electricity needs worry-free) for many hours not just 1 or 2 hours.otherwise after 20years,heavy-work laptops arent still laptop/portable and they are just using the mask of laptop when their usage is only 2 hours at most for our wok on such built-purpose.
  10. 1610ftw
    The Asus GX800 has a UHD screen that should be good, it is the only new screen in that size calss for ages.
    Yes I know that 16:10 has only survived in macbooks but that does not make it wrong to mention that it was a screen aspect ratio better suited to a laptop than 16:9.
    I would rather have a removable battery and let's say 10 to 20% less capacitiy if that means that I can exchange my battery when needed and without having to open my laptop and as there is a legal size limit anywa a 99WH battery isn't that big, I think I had a 96WH removable battery in a Thinkpad that I tested last year and it was not particularly big.
    In any case having to open a laptop and unscrew the battery on the go is not really practical even though at home it is not that big of a deal with the Clevo P870 series.
  11. Tyranus07
    Tyranus07 Notebook Consultant
    I really wouldn't pay extra money for a bigger battery or battery dock or anything about that. If you really want to play games you have to do it plugged to the AC power outlet, not to mention if you're overclocking. To me this kind of laptops are semi-portable, you can easily move it inside the house or to travel from time to time but they are not your daily partner to go from home to work, then to college, etc. My back just can't take that kind of load to often
  12. TheReciever
    I took out the battery from my laptop 6 months ago and still havent looked back. If I need a terminal for on the go I would look into it.
  13. XMG
    XMG Company Representative
    Batteries for laptops and portable devices have to be under 100Wh in order to comply with IATA regulations - this is when travelling or shipping by air. If a laptop needs 2 batteries, it's "legal" to ship with 2x 99Wh batteries - this was a hot topic for us as we had this setup in our XMG Walker VR backpack and when shipping them round the world we (of course) had to follow IATA regulations.
