Why does my screen keep dimming?
Discussion in 'Windows OS and Software' started by jkruer01, Jan 8, 2008.
  1. jkruer01
    jkruer01 Notebook Guru
    While my screen is unplugged it will randomly go back to being partially dimmed. I change my Power Option to "Max Performance" so it doesn't dim the screen but after a couple minutes the screen dims. I increase the brightness and then a couple minutes later it dims again.
    What's the deal?
    It just happened and battery is at 77%
    Thanks!
  2. Eleison
    Eleison Thanatos Eleison
    Go into your Power Options and adjust the default brightness for your power profile. The computer is resetting to the power profile's default. If your computer came with any extra power management software (Compal uses a program called Smart WatchDog), make sure that it is either disabled or also set appropriately.
