who has a inspiron 13 5000 2 in 1. Battery life?
Discussion in 'Dell' started by kojack, Sep 28, 2018.
  1. kojack
    kojack Notebook Virtuoso
    I have noticed my battery life is crap on my computer. 2 hrs max with the screen on 25% and just using the browser and email. I would like to know other people's battery life on their models. This seems REALLY low. It states my battery is fine, but I don't think it is!
    hmscott likes this.
  2. hmscott
    You can reduce browser CPU / GPU load - and battery usage - by disabling ad's, animations like jscript or flash, closing background tabs actively using CPU/GPU, and I've found this extension useful for Chrome:
    The Great Suspender
    Make your computer run smoothly by suspending the tabs you aren't using
    https://chrome.google.com/webstore/detail/the-great-suspender/klbibkeccnjlkjkiokjodocebajanakg?hl=en
    "A lightweight extension to reduce chrome's memory footprint. Perfect if you have a lot of tabs open at the same time. Tabs that have not been viewed after a configurable length of time will be automagically suspended in the background, freeing up the memory and CPU being consumed by that tab."
    It looks like someone has / is porting it to Firefox, haven't tried it:
    https://addons.mozilla.org/en-US/firefox/addon/the-great-suspender-port/
  3. custom90gt
    custom90gt Dellerator Super Moderator
    What does HWinfo64 say your battery wear level is?
  4. kojack
    I will check after and get back to you.
  5. tira
    tira Newbie
    My laptop battery have that problem. It said that "the battery was in the end of the cycle" (discovered after you press "Fn" + power on button). For your information, it only took one year from the first time i bought it (i bought the new one in the authorized seller). Amazing, isnt it
  6. kojack
    Did it make a big difference after you replaced the battery?
  7. kojack
    Ok, my battery life on the dell app is poor. I guess my battery was dying a slow death and it took a while to show on the health status. Next question, or questions. Are the batteries on ebay just as good as dell originals, and is there a higher capacity battery available for my notebook?
  8. custom90gt
    The ebay batteries are likely knockoffs so I wouldn't say their quality will be as good as the dell original. Having said that the cheap one's I've done for customers in the past worked ok. Sadly I have no idea if there is a higher cap battery for your laptop, not likely though.
    Dannemand and kojack like this.
  9. kojack
    I kind of figured as much. Most of the ebay batteries are not labeled dell. Probably from the exact same place as the OEM though. The way I look at it I can have 3 batteries from ebay from the price of one from Dell direct.
    I just started a new job, so I have had to catch up on everything. The xps 15 2 in 1 will be coming in the new year (again). My son will inherent my 5368.
    custom90gt likes this.
  10. Vasudev
