Which WWAN card for CF-19 AT&T LTE
Discussion in 'Panasonic' started by Biggie_Z, Jul 17, 2017.
  1. Biggie_Z
    Biggie_Z Notebook Enthusiast
    I'm trying to figure out which WWAN card to get for my CF-19 MK5 to use an AT&T LTE data SIM. There's so many different Sierra and Gobi card model #s out there I'm overwhelmed trying to figure out which one to get. If anyone running AT&T LTE in their Toughook please let me know which model WWAN card is compatible with the CF-19 MK5 running Windows 10 x64 and AT&T's 4G LTE bands. Thank you.
  2. EdFromBJCS
    EdFromBJCS Notebook Geek
    You will want the Sierra Wireless AirPrime MC7700 AT&T 4G LTE Card. The multi-carrier MC7355 Gobi 5000 would also work, but will probably be more expensive (bobjohnson.com sells the MC7700 for $129.99 and the MC7355 for $299.99)
  3. Biggie_Z
    Thanks for easing my confusion. One more question, is there any reason to get the more expensive MC7355 over the MC7700, or will they work the same?
  4. EdFromBJCS
    I'm pretty sure they work the same. The main difference is that the MC7355 will work on any major carrier, but the MC7700 will only work on AT&T.
  5. Biggie_Z
    Great, thanks for your help.
