Which screen is better? Alienware 13 oled vs alienware 15 4k
Discussion in '2015+ Alienware 13 / 15 / 17' started by GoodnGood, Sep 10, 2017.
  1. GoodnGood
    GoodnGood Notebook Enthusiast
    So I'm trying to get an Alienware and have two options: Alienware 13 r3 oled and Alienware 15 r3 4k.
    Has anyone seen both and have on idea on which looks better?
    Thanks for reading.
  2. Danishblunt
    Danishblunt Guest
    The oled does look better, but it's likely to get dead pixels much faster than the 4k panel.
  3. GoodnGood
    how long would it take before getting dead pixels on the oled?
  4. Danishblunt
    Danishblunt Guest
  5. GoodnGood
  6. ShotOfB12
    ShotOfB12 Notebook Consultant
    Having had multiple Samsung galaxy phones and a Vita, OLED is just godly. I can only imagine how good it looks on a 13" panel. I rather have OLED then 4k honestly.
  7. Wormwood
    Wormwood Notebook Evangelist
    I've not used the 15 R3's 4K display but based on other ones I've used I would choose the OLED.
  8. GoodnGood
    Does it seem to produce a more clearer image?
  9. GoodnGood
    How does OLED seem to compare to other types of screen in your opinion?
  10. Danishblunt
    Danishblunt Guest
    OLED is over saturated, the blacks are very deep and nice and the image is really colorful, but the color representation is terrible. Once you have an OLED you NEED to calibrate it, it's mandatory. It's as I said, OLED is better than the standard LED screen u're used to see, but it does like to break fairly easy.
    If you mind dead pixels a lot and want something that lasts really long, then go for something that has a great screen and calibrate it, once you did that it looks very good as well. You honestly won't notice that much of a difference when for example using a good calibrated panel for 1 day, then sleep 1 night and then use a calibrated OLED screen, you will notice that the colors are different, but you won't really consider either worse or better, just different.
