which model is 15" with removable battery and HD screen?
Discussion in 'Asus' started by etcetera, Nov 14, 2017.
  1. etcetera
    etcetera Notebook Evangelist
    I am looking for around 15.6" screen with these parameters:
    Removable battery, at least 8-cell and great runtime
    1920x1080 resolution
    space for 2 SSD drives, any format M.2 or 2280 or 1 M.2 and 1 2280
  2. etcetera
  3. bennni
    bennni Notebook Evangelist
    Without sounding a bit harsh - that meets almost none of the criteria given in your OP.
    Screen too small, no dual SSD, no removable battery (Although the battery does seem to be pretty good) - does have 1920x1080 resolution option at least. What exactly is it that you are looking for? There's a stickied form/template that might give a better idea of what you're looking for and therefore a better answer to your question.
  4. etcetera
    I want to keep my options open without locking myself into a certain format.
  5. sicily428
    sicily428 Donuts!! :)
    check for a Clevo n850
