Which is the best antivirus solution for Vista x64? Have tried Symantec...
Discussion in 'Security and Anti-Virus Software' started by channelv, May 27, 2008.
  1. channelv
    channelv Notebook Evangelist
    Symantec in Vista (at least x64) cannot be unloaded which is a huge annoyance. In XP, you could easily unload it from the menu so that it wasn't a memory hog or resource when not wanted, and could be easily loaded when wanted - but in Vista there isn't such an option. What antivirus program do you guys suggest?
  2. aan310
    aan310 Notebook Virtuoso
    NOD32 (if you want to pay like $30)
    Or for Free... Avira
  3. David
    David NBR Random Reviewer NBR Reviewer
    AVG is a pretty good one. Free too :)
  4. THAANSA3
    THAANSA3 Exit Stage Left
    Kaspersky Internet Security suite is the way to go. Otherwise, NOD32 is another great alternative.
  5. saturnotaku
    AVG is very good. It found some stuff on my system that Kaspersky couldn't. AVG is also less resource intensive and doesn't interfere with my games the way Kaspersky did.
  6. Prasad
    Prasad NBR Reviewer 1337 NBR Reviewer
    AVG is good.... till you experience the number of false positives it gives! Gonna try Avira myself :)
  7. makaveli72
    makaveli72 Eat.My.Shorts
  8. stewie
    stewie What the deuce?
  9. danjohnson88
    danjohnson88 Notebook Guru
    Hmmm, looking at the website it does look pretty good. I've been using Nod32 and it's a great. Only downside is it causes my harddrive to constantly run because it looks at every file.
  10. stewie
    I've been using BD products for many years now, it's really good compared to other AV software out there, they've been rated #1 for many years in different reviews. I know we cannot always trust reviews, but I do find it a very product.
    http://anti-virus-software-review.toptenreviews.com/
    They used to be called AVX(AntiVirus eXpert), a Russian based company, then later was bought by SOFTWIN(BitDefender) from Europe.
    If you don't need all the features in Total Security, you can always just go with Internet Security or just the Antivirus. I don't use all the features in TS either, but I went with it because if the files shredder feature.
    http://www.bitdefender.com/site/view/antivirus-comparison.html
    If you have another XP machine, you can always try their free version first, just like AVG's free edition, it doesn't have any real-time protection. The free version doesn't support Vista yet.
    http://www.bitdefender.com/PRODUCT-14-en--BitDefender-Free-Edition.html
