Which is a better spell-check for IE9?
Discussion in 'Windows OS and Software' started by lineS of flight, Mar 21, 2011.
  1. lineS of flight
    lineS of flight Notebook Virtuoso
    Hello:
    Just wanted to know - by user experience - which is a better (more fluid, seamless, efficient but unobtrusive) spell checker for IE9?
    Currently, I use Speckie. It's OK. I believe there is another app called ieSpell or something like that.
    Thanks in advance.
  2. newsposter
    newsposter Notebook Virtuoso
    The Sage and WordWeb will both do in-line spell check for many programs including IE.
  3. lineS of flight
    Thanks. But I have never even heard of these!!! Can you post links? In the meantime, I'll search online.
    Edit: This is regarding WordWeb and is from the FAQ on their site:
  4. shakennstirred
    shakennstirred Notebook Evangelist
    i have used ieSpell for years
    does the job great
  5. ATC
    ATC Notebook Deity
    I've used IEspell for quite a few years and only recently started using Speckie and there's no comparison between the two; IEspell feels like a program for Win 95 in comparison. Speckie is also fully supported in IE9 where IEspell I found was very buggy.
  6. Texanman
    Texanman Master of all things Cake
    if you want to go one step further you could use a autohotkey script that automatically changes words when you misspell them... but it would require a little work to set up
  7. lineS of flight
    That, I'm afraid, is a little beyond me at the moment!
  8. anseio
    anseio All ways are my ways.
    I'm using Speckie.
  9. lineS of flight
    Btw, when you folks use Speckie + IE9 do you notice an intermittent lag while using GMail?
  10. anseio
    None that I've noticed, but I don't email too often.
