Which Display to go for in AW17 with GTX1070
Discussion in '2015+ Alienware 13 / 15 / 17' started by vish120292, Dec 29, 2018.
  1. vish120292
    vish120292 Notebook Guru
    Hi ,
    Since GTX1080 version seems unreasonably expensive in UK (and no i7 option only i9), i have decided to get GTX1070 Version, Which display do you recommend I get with it?
    Below are the 4 choices I have.
    1) 17.3" FHD 1920x1080 60Hz Anti-Glare NVIDIA G-SYNC Enabled 300-nits IPS
    2) 17.3" UHD 3840x2160 60Hz AG NVIDIA G-SYNC 300-nits IPS w/ Tobii IR Eye-tracking
    3) 17.3" QHD 2560x1440 120Hz AG NVIDIA G-SYNC, 400-nits, TN+WVA Tobii Eye-tracking
    4) 17.3" QHD 2560x1440 120Hz Anti-Glare 400-nits with TN+WVA Tobii Eye-tracking
    5) 17.3" FHD 1920x1080 60Hz Anti-Glare 300-nits IPS - Included in Price of 1750 GBP.
    Mainly I will be gaming, Running VMs and doing day to day tasks. No Editing or anything like that. So I guess UHD is out since it makes no sense for gaming.
    What will you choose?
  2. kevin_172
    kevin_172 Notebook Consultant
    I would go with option 3 myself
    vish120292 likes this.
  3. dsmrunnah
    dsmrunnah Notebook Enthusiast
    I have 3 on my gtx 1080 version and it's great. It's a TN panel, so the colors aren't as nice as option 2, but the 120Hz more than makes up for it.
  4. alberty
    alberty Notebook Enthusiast
    Do you have back light bleeding? I am also thinking about buying the same display but i hate backlight bleeds.
  5. liviu2007
    liviu2007 Notebook Enthusiast
    number 3. is good. i have it on my aw17 r4 gtx1080
  6. Ben7078
    Ben7078 Notebook Enthusiast
    I have number 3 with is miles better that the option 5 I had on my last
  7. vish120292
    Thank you very much for the replies.
    I keep jumping between Aorus X7 dt V8 and AW17, I will go for the QHD 120Hz Panel if I decide to go with AW17 :)
