where to find optimized and debloated with msmg isos.?
Discussion in 'Windows OS and Software' started by raptorddd, Aug 16, 2019.
  1. raptorddd
    raptorddd Notebook Geek
    theres 1 guy here that shares his iso but seems debloat is too extreme.
    i have already search but cant find a place that already created iso to download.
    thanks
  2. 0lok
    0lok Notebook Deity
    From experience here in the forum, the most reliable bloatware free OS is from Ultra Male as he test the OS before sharing. His debloated OS is not extreme compared to Sixor. Ultra Male has not made a new one and he removed the links of his previous work. I am assuming/hoping that when the new Windows 10 19H2(AKA 1909) will release and MSMG will successful fix there program that won't have issues making a debloated ISO, Ultra Male will share his work again. ^_^
    Vasudev and raptorddd like this.
  3. raptorddd
    thanks i was referring to this one
    http://forum.notebookreview.com/threads/windows-10-nobloatware-edition.810557/
    havent seen sixor thread i will try to search for it. NEVER MIND its the sameguy sorry.
    or i would like to make my own but...... something i do not understand like why integrate netf 3.5?
    Vasudev likes this.
  4. 0lok
    0lok Notebook Deity
    Ultra Male/ Phoenix made this guide. It's old and I don't know how to use the program as I did not try due to lack of time and I have a weak Laptop.
    Hope that helps.
    Edit:
    Oh also I don't know what to look for if the OS I made would work properly or something is broken that I wouldn't know. ^_^
  5. raptorddd
    works properly as long as you use suggested iso image as new 1903 keeps reinstalling removed apps when you update. this is what developer said
    (OP)
    Yes in that case it will be useful but you need to keep in mind that the current ToolKit will only work with v1809 (10.0.17763.1) and v1903 (10.0.18362.1, 10.0.18362.30) source images.
    Haven't still tried with integrating updates post component removal to know whether it will restore the component or not for v1903.
    As far as with v1809 there are no issues with component removal and using the WU.
    Vasudev likes this.
  6. Vasudev
    I did make one for v1803 and v1809 but not all UWP are removed since I prefer a W10 image that's suited for everyone and not just like enthuasiasts. Its fast and takes up less space than stock OS. Takes around 9GB after netfx3.5 is installed and w/o netfx3 it takes up 8.65GB of space.
    raptorddd likes this.
  7. Anthony Goodman
    Anthony Goodman Newbie
    This is what I am looking for, Ultra Males releases are perfect and what I have been using for the last year.
    Now Windows has decided all on its own to update to the latest version and put Windows Defender, Edge, Skype and all sorts on there and the machine is running so slow and sluggish.
    I am going to need to reformat and reinstall so I am needing to find the current version from Ultra Male to do it with.
    Does anyone have a link to the post please with it in or has one not been released?
  8. Mr. Fox
    Spend under $5 USD on LTSC and you will not need to worry about UWP feces ever again. There is none of the butt-crust bloatware filth. Not even Micro$loth store is resident, so you don't have to worry about some dumb-dumb using your computer inadvertently importing any digi-cancer while your back is turned. And, you won't have to worry about drive-by version updates by the Redmond Mafia screwing things up. There is no new version to update to... it's LTSC. No ISO modding or toolkit required... no fuss, no muss.
    https://www.ebay.com/itm/Winsdows10...time-genuine-License-Key-INSTANT/383049397282
    Vasudev and Papusan like this.
  9. Vasudev
    Can Home users and small business users use LTSC version? Is it Legal? I did find some nice deals on Win 10 pro for same amount.
    Mr. Fox likes this.
  10. Mr. Fox
    I've been doing it for a long time and it works. No special activation tricks, just activate by phone the same as I do Windows 7 and other versions of Windows 10. No issues here. The Redmond Retards are not stopping or interfering with it. So, I don't know the answer to the second question and, quite frankly, it wouldn't change anything even if I did. Pro is still chock full of UWP cancer bloatware and so is regular Enterprise (non-LTSC). Although, I think (don't quote me on it, just assuming,) the Enterprise versions have a bit less of the telemetry filth.
    Maybe our Bavarian Brothers will put the smack-down on the Digi-Nazis by getting a $4B USD judgment for privacy violations and nobody will need to think about telemetry in the near future.
    Papusan, raptorddd and Vasudev like this.
