When will the next W10 build arrive?
Discussion in 'Windows OS and Software' started by thegreatsquare, Mar 17, 2021.
  1. thegreatsquare
    thegreatsquare Notebook Deity
    I just got a notice than 1909 support ends 5/11/21. Should I be able to stretch it out till then?
  2. epguy3
    epguy3 Notebook Evangelist
    only the home & pro editions of 1909 will be EOL on May 2021 while the enterprise & education editions of 1909 will continue to be supported until May 2022.
    next W10 build is 21H1 (build 19043, which is really 2004/20H1 with two EPs [aka. enable packages] installed) which is due sometime in spring 2021. so yeah you can continue to use 1909 until 21H1 is ready for public release
  3. KING19
    KING19 Notebook Deity
    I caved and installed it because i got annoyed by the notifications warning me that support will end for 1909 soon and also Microsoft will start forcing people to upgrade to 20H2 anyways.
    I recommend reinstalling windows when you upgrade to 20h2 so you wont run into issues because there are a lot of major changes in the 20h1 update. So far i havent run into any issues as of yet but i'll soon find out.
    Vasudev likes this.
  4. StormJumper
    StormJumper Notebook Virtuoso
    When it ends they most likely will do a update to update the 1909 to the latest build so one shouldn't worry til that time comes.
