Whats the difference between I6, v6 ect
Discussion in 'Motorized Vehicles' started by aan310, Jul 2, 2009.
  1. Azone
    Azone Notebook Evangelist
    Well, a Flat 6 is an engine with six cylinders, arranged horizontally, in two banks of three cylinders on each side of the crankshaft. The pistons move back and forth in opposite directions at the same time. Basically, just another term for a boxer engine.
  2. J12
    J12 Notebook Evangelist
    Why do newer cars still use Inline 6 engines? I've primarily though of inline 6's as older technology and being phased out by V-6's.
  3. K-TRON
    K-TRON Hi, I'm Jimmy Diesel ^_^
    Straight engines are actually less prone to camshaft irregularities, since torsional forces about the camshaft's axis are less common.
    Inline engines are widely used in the Industrial market and have been for years. In the on road truck industry almost every diesel for the last 15 years has been an inline engine, with exception of the CAT 3408, and the 92 series Detroits.
    Plus a single head is generally preferred over separate heads.
    Back in 1958, when the first VEE type on road diesel became available, It had a supercharger on each side. Later it was simplified into a larger blower centralized in the VEE.
    K-TRON
  4. Syndrome
    Syndrome Torque Matters
    You usually get more torque out of a inline engine than you would out of a V engine of the same displacement. And we all know that torque is what matters, not HP. ;)
  5. aan310
    aan310 Notebook Virtuoso
    So that means i must have decent torque in my tiburon :)
  6. Syndrome
    Well, lets add a turbo... then you can say you have some torque. ;)
  7. aan310
    hehe, not a bad idea :p
    jk
  8. Syndrome
    I'm not sure if Hyundai's plastic motor blocks can handle that much boost. ;)
  9. houstoned
    houstoned Yoga Pants Connoisseur.
    some of hyundai's vehicles used outsourced motors from different companies in the past. i know their tuscans and other v6's were sourced from honda. i wouldn't be suprised if they are continuing that trend, even if to a certain extent.
  10. aan310
    i don't actually know about my specific car, but i was told that the tiburon had higher dependability than many other hyundai cars, which i guess maybe im running a Mitsubishi, Toyota or Honda motor?
    Idk, im just tossing this out there
