What the best/top CPU upgrade M17X R4 ??
Discussion in 'Alienware 17 and M17x' started by Ritz1209, Jun 8, 2019.
  1. Ritz1209
    Ritz1209 Notebook Guru
    Hi everyone,
    What the best/top CPU upgrade M17X R4 I can buy.
    I'm currently on 17 3940xm [​IMG]
    Or
    Is it best just to overclock my current CPU in the bios?
    Will that help to gain more performance?
    Thanks
  2. Arrrrbol
    Arrrrbol Notebook Evangelist
    That is the best CPU for your system, definitely try overclocking it as you will gain quite a bit more performance.
    M18x-oldie, Papusan and Ritz1209 like this.
  3. Ritz1209
    Cheers pal
    Is there a guide on how to do that within the bios, I know you can overlook CP in the bios to level 1 2 3?
    Never done overclock on alienware before so I'm not to sure the best way here .
    Any help is much appreciated
    Ritz
  4. M18x-oldie
    M18x-oldie Notebook Consultant
    Better improve your cooling first, OC brings much excess heat with it ;)
    Arrrrbol, Papusan and Ritz1209 like this.
  5. Ritz1209
    Hi pal,
    How?
  6. M18x-oldie
    Good paste and a stronger fan, pal.
  7. Papusan
    Use Grizzly Conductonaut Liquid metal. Google it. Or search within this forum.
    M18x-oldie, Arrrrbol and Ritz1209 like this.
  8. Ritz1209
    Cheers will research about it thanks
  9. M18x-oldie
    Papusan likes this.
  10. mariussx
    mariussx Notebook Evangelist
