What LCD Monitor works with SZ6-series ?
Discussion in 'VAIO / Sony' started by jimmy-floyd, Aug 14, 2008.
  1. jimmy-floyd
    jimmy-floyd Notebook Evangelist
    Want to buy an LCD Monitor for my SZ (Dont have SZ Dock station, and dont want to buy it.) and connect it to SZ's VGA port. But, some people told that there is a limit in Resolution in such connection type, if so, tell what max. resolution is supported in VGA connection?
  2. Phil
    Phil Retired
    I use a VGA connection with a HP w2207 1680*1050 screen. The image quality is perfect. I would not go larger than that on VGA.
  3. jimmy-floyd
    PhilFlow
    thanks for answer. and another questions:
    1) a lot of Monitors i have seen have D-Sub port, is it the same as VGA ?
    2) and what kind of cable i must buy to connect Monitor to SZ ?
  4. jimmy-floyd
    for e.t.c if i'll buy 24" 1920*1080 Monitor, will it work with SZ via VGA on 1680*1050 resolution ?
  5. Phil
    Phil Retired
    1) yes the same
    2) VGA cable
    3) It will work but it will look ugly. A LCD should be tun in it's native resolution.
    Connecting a 24" LCD with 1920*1200 resolution is a bit of a gamble, it may work but quality may not be optimal.
    I would recommend not going larger than 22". But I must say i have never tried it myself. Maybe some people did and can comment on it.
