What is TouchCheck? And how to disable pointer stick?
Discussion in 'Dell Latitude, Vostro, and Precision' started by guy121, Dec 4, 2007.
  1. wankel
    wankel Notebook Consultant
    I got to the buttons settings, but I dont see where it says virtual scrolling?
  2. nm88
    nm88 Notebook Evangelist
    Double-click tray icon -> Device Settings tab -> Settings -> Virtual Scrolling.
    There are also three submenus for fine-tuning scrolling.
  3. wankel
    When i click the settings tab all i see is "overview" and "buttons". When i click on buttons it saids right and left button, and when i click on overview is says patent. Maybe the one i installed doesnt have it?
  4. jeffkew
    jeffkew Notebook Enthusiast
    You know, I am using XP pro. If you are using Vista that could be the problem. Make sure you download the driver for the correct operating system. You can alway reinstall the dell touchpad driver from their website if you continue to have problems.
  5. wankel
    Yeah im using vista ultimate 64, i know i downloaded the correct driver as well. Maybe its just not supported. Thanks for all the help, its much appreciated :)
  6. nm88
    I am using Vista 32-bit and it's working fine.
    Are you sure you have the Synaptics device?
  7. wankel
    I have the alps device. Im assuming I cant use the synaptics driver on it?
  8. jeffkew
    Oh - that's probably the problem, I'm sure synaptics only makes drivers to work with their own hardware.
  9. nm88
  10. stokjok
    stokjok Newbie
    Hi, I have had the same problem, did you ever come up with a fix? I have a dell 430 and it also had a pointer, does anyone know how to disable? and how to get the synaptics driver to show all options instead of just overview and button
