What is the best way to recharge a cell phone battery?
Discussion in 'Off Topic' started by Homer_Jay_Thompson, Aug 8, 2007.
  1. Homer_Jay_Thompson
    Homer_Jay_Thompson blathering blatherskite
    Are cell phone batteries similar to laptop batteries? Should I use my cell phone until the battery dies or should I only use the cell phone until 10%-20%?
  2. Jeff
    Jeff Notebook Retard
    only with old phones is it necessary to discharge it fully. on the new ones it doesn't matter at all. a battery's life ( untill a full charge starts to diminish rapidly) should be longer than the phone.
  3. AKAJohnDoe
    AKAJohnDoe Mime with Tourette's
    Most modern batteries have a limited number of recharges. If you use half of the battery capacity, then charge it up, you will have used half a charge. I would not completely flatten a charge, and would top it off whenever possible.
