What Is PCI Data Acquisition and Signal Processing Controller
Discussion in 'Panasonic' started by Toyo, Nov 18, 2011.
  1. Toyo
    Toyo Notebook Deity
    It shows up in Device Manager with Code 28 with no driver. I have never not had the driver automatically installed for this before.
  2. Alex
    Alex Super Moderator
    What model of Toughbook ?
    I can look later if I have the same model
  3. rick 10p
    rick 10p Notebook Enthusiast
    I have this same issue, and have yet to find an answer.
    My Mo. no.'s are: CF-30FTSAZAE (Win XP) & CF-30FASCZAM (Vista).
    Any help would be great. Also I can't get the Panny Config. to work for me ?
    Rick 10P
    2 X CF-29H's
    2 X CF-30F's
  4. Toyo
    Toyo Notebook Deity
    Sorry Alex. It is on my 30 MK2.
  5. Toyo
    Toyo Notebook Deity
    What is the Panasonic Config? Are you talking about the web site configuration?
  6. db04p71
    db04p71 Notebook Deity
    Model Number:
    CF-30FASCZAM
    Status:
    DISCONTINUED
    MSRP:
    $4,949
    Description: WinXP (Vista COA), Intel Core 2 Duo L7500 1.60GHz (Centrino), 13.3" XGA Touch, 80GB, 1GB, Intel 802.11a/b/g, TPM1.2, Bluetooth, Emissive Backlit Keyboard, GPS, No Drive
    The CF-30FTSAZAE is a UK model. It will not show in the configurator. However, it is probably the same as this one.
    Model Number:
    CF-30FTSAZAM
    Status:
    DISCONTINUED
    MSRP:
    $4,249
    Description: WinXP (Vista COA), Intel Core 2 Duo L7500 1.60GHz (Centrino), 13.3" XGA Touch, 80GB, 1GB, Intel 802.11a/b/g, TPM1.2, Bluetooth, No Drive
    As for the missing driver I think it will be this one for both, XP and Vista:
    http://pc-dl.panasonic.co.jp/dl/download/file/011087/s/489456236a2a2743/etm_1930_22_d071197.exe
  7. ares93
    ares93 Notebook Evangelist
    I might be talking out of my on this one, but isnt the CF-30 GPS PCI-e based? Cause "Data Acquisition and Signal Processing Controller" sounds awful lot like a gps.
    Cheers
    Pay no mind to my drunkenly ramblings...
  8. Toyo
    Toyo Notebook Deity
    ETM was it. I had uninstalled it when I installed W7 last night. I had installed the newer version this morning and now it is gone. Gotta be it.
    Thanks!
  9. SHEEPMAN!
    SHEEPMAN! Freelance
    We crossed posts but extended thermal module was it for me too.
  10. Waldeck
    Waldeck Notebook Geek
    I have a CF-30FQAXAE-BP, it is set up for Canada but the E is for the UK. Must have come from BP in England and sent to the job site in Canada, just a guess. Have the same problem and it is a Novatel Expedite EU860D. Think the D is a Dell spec but not sure. Driver is on the Canada site;
    https://panasonic.ca/english/customercare/sandd/softwareQuery.asp
    Bob.
