What is Normal Battery Wear Level?
Discussion in '2015+ Alienware 13 / 15 / 17' started by BigBoss5090, Jun 19, 2017.
  1. BigBoss5090
    BigBoss5090 Notebook Geek
    What is normal battery wear level on a 15 R3? I had my system for about 3 months and I have 13.7% Wear Level according to hwinfo
  2. don_svetlio
    don_svetlio Notebook Virtuoso
    Do you cycle the battery a lot? Since I've been running plugged in for the most part for a year now with about 10% wear level/lost capacity.
  3. namaiki
    namaiki "basically rocks" Super Moderator
    If you game on battery or do anything power intensive that drains the battery quickly, it can also exacerbate battery wear.
    If your battery reaches 50% battery wear within the warranty period that might be considered faulty but don't quite me on that.
  4. shadowyani
    shadowyani Notebook Deity
    Mine started at 2% and suddenly dropped to 7%. The one before that started at 15% though so meh, I guess I'll take what I can get lol.
  5. MogRules
    MogRules Notebook Deity
    It seems like it goes up if your discharging the battery right down. I changed my battery warnings to go critical at 40% so I don't run it down.
