what is hp connection manager?
Discussion in 'HP' started by nina-sky, Nov 28, 2011.
  1. nina-sky
    nina-sky Notebook Enthusiast
    1.what is hp connection manager?
    2. what is intel management engine interface?
    3. and i uninstalled idt hd audio, but the sound still works, why?
  2. MagusDraco
    MagusDraco Biiiiiiirrrrdmaaaaaaan
    2. intel management engine interface is some chipset/processor stuff.
    1. hp connection manager is the superior updated version of hp wireless assistant that doesn't crash and use up 25-50% of your cpu when that happens.
    3. you still have audio drivers installed (even if they are just microsoft's default audio drivers or something)
  3. nina-sky
    1. do i need intel manegement engine stuff?
    2. what the hell is hp connection manager again? do i need it?
    3. then why should we have idt audio installed?
  4. MagusDraco
    1. Yes.
    2. it lets you turn your bluetooth radio on and off if you use that. Otherwise you cannot turn bluetooth on/off separately from the wireless radio. You can't turn bluetooth off separately period with the keyboard shortcut key, but at least it will turn off with the wireless when you turn the wireless radio off.
    3. You should have it installed since it contains the proper drivers, the integrated microphone array drivers, and the hdmi audio-drivers get wonky if you don't have it installed (doesn't switch on/off properly...well sometimes it doesn't do that anyway. You have to go and set the defaults up properly with the idt connection manager)
  5. nina-sky
    1. why?
    2. i dont use bluetooth.
    3. sound works fine, i think i dont need idt stuff?
  6. MagusDraco
    1. Because. It's part of the chipset drivers and/or cpu drivers for your computer. You need those drivers to take full advantage of the hardware. I don't know what it does but you really shouldn't be uninstalling drivers just because.
    2. Well, unless things have changed the bluetooth radio defaults to on on a new install of the envy 14. Because of that it will drain a a tad bit more power than if you turned it off (and then if you really don't want the hp connection manager..you can uninstall that program after turning the bluetooth radio off)
    once the radio is turned off it stays off, even through reformatting the computer.
    3. Well. the IDT stuff is again, the proper drivers and software for the audio chip. There are compatible ones built into windows but you won't be able to control EQ settings or easily set the default speakers if/when issues arise.
    You probably can set default speakers through windows settings anyway though.
    Still, there's no actual reason to not install this specific software. It uses 7.34 MB of ram and no cpu when idle. When you open it up a separate process starts that uses 20mb of ram (only while you're messing with settings).
  7. nina-sky
    1. really? how can i now if my bluetooth is on? i mean, i have disabled it in device manager.
    2. actually, i got idt audio process automaticly when starting pc, thats why i uninstalled it. dont want extra processes...
  8. 2.0
    2.0 NBR Macro-Mod® Super Moderator
    Nina-sky, welcome to the forum.
    I closed your other question threads. Rather than start new threads for each question, you would be better served participating in the Envy 14 Owner's lounge.
    http://forum.notebookreview.com/hp-...s-sandy-bridge-2xxx-series-owners-lounge.html
    BTW, search on this site is borked. Best way to search is to go to Google. Then type:
    site:notebookreview.com [then your question]. For example, let's say I want to search for how to change RAM in Envy 14. I'd go to google and type:
    site:notebookreview.com how to change RAM in Envy 14
