What External DVD/CD drive works with older Toughbooks?
Discussion in 'Panasonic' started by Waldeck, Mar 16, 2020.
  1. Waldeck
    Waldeck Notebook Consultant
    I have 2 external DVD drives, both will not work with my CF- M34's.
    One is a Tosiba PA3761U-1DV2. This is with out it's own power supply and trips the USB outlet.
    2nd is a LG GE20LU11. This has it's own power supply but does not show up or will not allow me to install an OS (XP or 2000).
    Any one Know a DVD/CD drive that does work, I hear they can be finicky.
  2. Geraout
    Geraout Notebook Consultant
    Panasonic Toughbook CF-VDRRT3U
    toughasnails, Shawn and Waldeck like this.
  3. Waldeck
    Shawn likes this.
  4. ADOR
    ADOR Evil Mad Scientist
    All the panasonic ones are set up from the factory as master, you can pin mod them the work.
    Also getting a cheap usb case and putting one from a 28,29,30,73,74,51,52 will work as well. TEAC is the brand they used from the factory.
    Shawn likes this.
  5. Waldeck
    Thanks ADOR, what do you mean by pin mod, is that like a link you have to change over. I have a 29 DVD I think I'll try that just to see how it works. I think I have a connector that fits the drive to a usb some where. My Panasonic one should be here in a couple of days, but in the mean time I will have a go.
    Well the adapter was for a CF-25 floppy drive to a parallel port. Looks like it may fit a CF-27 CD drive. AnyWho back to the drawing board.
  6. ADOR
    That pin mod is for using a NON panasonic dvd drive in a panasonic case like the CF-28 and CF-29. In the dvd caddy it's self there are two pins that have to be touching for it to reconize the non panasonic dvd drive as a master.
    That mod came out as the early caddy's were holding only CD reader and out of other old laptops we were dropping DVD readers into it.
  7. Waldeck
    I seem to remember that now, trying to get a CF-25 going and with a desktop with 2 hard drives on Win95, you had to say which drive had the OS. We are spoilt with Win10, it does it all for you.
  8. ADOR
    Also I think it's a 8gb or 6gb limit the CF-25 can physically see. I think the trick you can use is if the hard drive is bigger than that is to partition it to a size no larger than that and just have multi able partitions.
  9. Waldeck
    My 1st computer was a Sincler not sure if thats the right spelling. The Hard drive was measured in MB and the Ram in KB. The printer was a single color 2 inch calculator roll. Had to press 2 or 3 keys to get a figure. It attached to your Black/White TV.
  10. Shawn
    Yup. 8086 here. 30mb MHM hard drive. 640kb ram. I had an amber monochrome display. EGA I think. Sears display model.
    About a billion years ago.
