What does "Enable InstantResume' do
Discussion in 'Lenovo' started by Paul386, Apr 10, 2009.
  1. Paul386
    Paul386 Notebook Evangelist
    When I click this nothing happens. From what I understand it is suppose to keep my network connection alive when I close the lit (put the laptop to sleep), however there is no indication that it is on or off. For example, when you click "Enable InstantResume" it doesn't become "Disable InstantResume".
    I wonder that it is working sometimes (even though I don't want it on right now) because when asleep my battery drains much faster than it normally would.
  2. Paul386
    Bump!!!!!!
  3. Paul386
    Bump!!!!!!!
  4. equinoxe07
    equinoxe07 Newbie
    Same behaviour on my x301 and T61.
    Any help ?
  5. mikec
    mikec Notebook Evangelist
    Paul386,
    From Menos in another thread:
    "'Instant Resume' simply delays the close lid action, turns off the display and, if set, locks the account. InstantResume is configurable and can be turned on/off depending on the wi-fi network at hand.
    I turned this feature off at home, and left on in office."
    So it is not a "faster" version of sleep/resume - it just delays when sleep kicks in, so if you close the lid and move to a difference conference room, you are still "on".
  6. pk_volt
    pk_volt Notebook Consultant
    Hi there,
    so isn't this bad for the harddrive if your computer is still on and you're moving around?
  7. Paul386
    I understand this now. When I press "Enable Instant Resume" nothing changes and the option doesn't change to "Disable Instant Resume". In other words the "button" doesn't seem to function.
  8. davidixon
    davidixon Notebook Guru
    You need to have ThinkVantage Active Protection System installed for InstandResume to function properly.
    I had issues trying to get it to work when I first got my T410 and found that bit of information buried in Power Manager's Help file.
  9. Paul386
    Hmmm... I prefer not to use Active Protection System because I have a SSD.
  10. infinus
    infinus Notebook Evangelist
    If you have an SSD I would imagine there wouldn't be too much benifit of instant resume considering how fast the machine should come out of sleep.
