what does drive spanning in Vista do?
Discussion in 'Windows OS and Software' started by hehe299792458, Aug 7, 2008.
  1. hehe299792458
    hehe299792458 Notebook Deity
    I have three HDDs of varing sizes and I want to get rid of all the drive letters. My mobo supports JBOD. Should I use that or the Windows "spanning discs" function? I know for JBOD that if one disc fails, I only lose the data on that disc (as opposed to loosing all my data on RAID0 arrays). Does "spanning discs" function in the same way - not destroying all my data when a single drive fails?
  2. fonduekid
    fonduekid JSUTAONHTERBIRCKINTEHWLAL
    AFAIK, spanning is a process for dividing / spreading out large volume of data across several storage medium.... and multi drive data spanning is a feature to enable users span the backed up data onto more than one drive... this includes hard disks, shared network locations and so on..
    Though I don't know for sure which one is better among the choices you have listed!!
  3. Icewalker
    Icewalker Notebook Consultant
    You're right about JBOD, and you should use that if your hardware supports it.
    To answer your other question: Vista's disc spanning is a software-level feature, it just logically concatenates/merges two or more hard discs so they appear as one (huge) drive. Yes, those discs will appear under one drive letter in Explorer and other programs.
    But -- again, you're right -- if either of those "spanned" discs fails, all data will probably be lost. It's no RAID or JBOD.
    The only good use of Vista's "disc spanning" I see is to work around hard drive size limitations in Vista, that could be a problem for some people.
    Hope this helps.
    PS: More info on Vista's disc spanning here:
    http://technologynews.ws/597/disk-spanning-unique-feature-in-vista/
  4. Icewalker
    You're absolutely right:
    http://en.wikipedia.org/wiki/Disc_spanning
    This term is usually applied to backup software or optical disc burning.
    But Microsoft don't care, so they called Vista's logical drive spanning "disc spanning" to create more confusion ;)
    From the context it was clear what hehe299792458 meant, though.
  5. hehe299792458
    So Vista's "disc spanning" feature is not a software version of JBOD?
  6. Icewalker
    Sorry, I confused JBOD and RAID in my original reply, so when I recommended JBOD I meant RAID.
    Both JBOD and Vista's "disc spanning" just concatenate/merge several disc into a logical entity, so those will appear as one logical drive. No data redundancy/failure tolerance is provided.
    Yes it appears it is. Sorry for the confusion.
    Hope this is clear now.
