What do I need?
Discussion in 'Panasonic' started by TheSpiritOfRadio, Jun 26, 2020.
  1. TheSpiritOfRadio
    TheSpiritOfRadio Notebook Consultant
    Yes I found an adapter for the card and bought some u.fl to MHF4 antennas
    I have yet to plug in a new card. so no BIOS issues yet. lol The problem is physical fit. But now that I know that only certain cards will work with certain laptops, I will probably start running into software issues once I plug one in. again, learning so much...
  2. TheSpiritOfRadio
    Ive never had success with Bluetooth and actually getting it to properly work on my Toughbook (using 7260 card).
    I finally found a proper A/E key adapter yesterday on ebay (Adapter Card M.2 NGFF To Mini PCI-E For Laptop PC Electric Bluetooth)
    and wifi card (Intel Dual Band Wireless-AC 8265NGW Bluetooth NGFF P/N 851594-001 / 01AX704)
    Wish me luck!!
    EDIT Literally the best visual depictions ive seen to distinguish these cards... thank you
    Really? ok recommendations?
  3. BaRRmaley
    BaRRmaley Notebook Deity
  4. TheSpiritOfRadio
    HMM, ok i have an intel 7260 already.... guess ill return the other card...
  5. Shawn
    If you want to play with a faster/better wifi card, try a Broadcom/Dell DW1830.
    NGFF/M2 form factor but it uses 3 antennas.
    Worked in my FZ-G1
    DW1830 AC BCM943602 NGFF M.2 1300Mbps BT4.1
    UNCNDL1 and BaRRmaley like this.
  6. TheSpiritOfRadio
