What cooling pad do you use with the area 51m and what are your temps with and without?
Discussion in 'Alienware' started by Zellio2013, Apr 29, 2019.
  1. Zellio2013
    Zellio2013 Notebook Guru
  2. TheReciever
    TheReciever D! For Dragon!
    If you're serious about a cooling pad then most people in that category opt for the cooler master u3 modded with 3x 120mm fans powered externally.
    This way you can also have a fan controller and USB 3.0 hub too or more depending on how creative you get.
  3. MogRules
    MogRules Notebook Deity
    99% of the benefit of the cooling pad, no matter what brand , is the fact that it elevates the back and allows more air in. The fans that come with them are useless. You can get the same results using anything to elevate the back really, unless your willing to heavily mode the cooling pad.
    If you have a gaming laptop, or any laptop really that will benefit from more air flow then elevating the back even using something as dumb as bottle caps will help.
  4. cucubits
    cucubits Notebook Evangelist
    +1 on just elevate the back. I keep my back feet on temporary 1cm wood blocks until I print something nice.
    Also, I can't understand why the intake grill cutouts are so small. I'm 100% sure it would help if I cut large round holes in the case and put wide fan grills there. (I don't know about 51m, this is for another machine).
  5. Zero989
    Zero989 Notebook Virtuoso
    The fans do nothing if there are no vents on the bottom. Taking the bottom cover off can make all the difference.
  6. etern4l
    etern4l Notebook Deity
    I measured, and the statement it is gnerally incorrect, at least in the case of the m15. The benefit is split about 30% fan - 70% lifting the back.
  7. TheReciever
    That's heavily depends on the model in question
    Papusan likes this.
  8. VoodooBane
    VoodooBane Notebook Consultant
  9. etern4l
    MogRules likes this.
  10. Fire Tiger
    Fire Tiger Notebook Deity
    Thats an insane amount. If you wanted to go overkill you can get the Notepal U3 and install 3 x desktop fans and hook it up to a power supply for half the price.
    DreDre, MogRules, RMLJD and 2 others like this.
