what box to check on disk clean up?
Discussion in 'Windows OS and Software' started by jaxxx, Mar 1, 2008.
  1. jaxxx
    jaxxx Notebook Consultant
    which ones should I check on disk clean up??
  2. goofball
    goofball Notebook Deity
    whatever you don't think you need to keep?
  3. Shadowfate
    Shadowfate Wala pa rin ako maisip e.
    Yes pick the ones that you do not really need. Most likely Temporary Files and Memory Dumps.
  4. jaxxx
    are they all safe to clean up?
  5. Gintoki
    Gintoki Notebook Prophet
    Yes, all of them are safe to clean up.
  6. jaxxx
    whats "hibernation file cleaner"?..i have 2.97 gb of stuff there
  7. Gintoki
    Whenever you use hibernation, it stores files on your HD for when it wakes up. After you come back from hibernation and save your open files, these hibernation files are no longer needed. AFAIK.
  8. jaxxx
    thanks..........
  9. Gintoki
    You're welcome. Be sure to post if you have any more questions.
  10. Riemen
    Riemen Notebook Enthusiast
    The hibernation file is needed. Its size depends on the size of your RAM.
    If you delete it, hibernation will no longer work and the option will be hidden, until you enable it again via a command line switch.
    As far as i know, there is no GUI option for this. (For the command, that reenables it, just google.)
