What ASUS USB Charger Plus?
Discussion in 'ASUS Gaming Notebook Forum' started by RampageX, Sep 29, 2011.
  1. RampageX
    RampageX Notebook Consultant
    Noob question, I KNOW! But, i need it answered. What is it? What does it do? Finally, Does it matter if i remove it or never use it?
  2. RampageX
    Anyone gonna answer?
  3. RampageX
    Please Answers!
  4. Catzoo
    Catzoo Notebook Evangelist
    Just google it instead of spamming ><
    It allows you to charge an iPod faster.
  5. lsn
    lsn Notebook Enthusiast
    congratulations. When you start typing Asus USB in to Google, Google suggests Asus USB charger plus.
    guess what pops up?
    Now that some time has passed, how about a bump for this thread and a user who is willing to lend some convenient information?
  6. Hrogi
    Hrogi Notebook Consultant
    ok here is more info..
    If you slow charge a device the battery will last longer.
    So Ausu hating Apple, made a simple program to help you destroy your apple products faster..
    So you will in turn hate apple and buy product made by Asus instead.
    This is just 1 idea...
  7. ALLurGroceries
    ALLurGroceries   Super Moderator
  8. bigbadsteve
    bigbadsteve Newbie
    Asus software, like the drivers they write, is frequently buggy, and usually only updated for a few months after a computer's manufacture date, when it's frequently still buggy.
    All the local Asus rep could tell me about Asus USB Charger Plus when quizzed during their short free-advice-after-purchase period was, "Oh, you're better off leaving all our supplied software running." I've learnt since from sad experience that this is about the opposite of the actual reality.
    Asus USB Charger Plus is a buggy piece of crap. Attached is a screencap of the program's options. Looks like the program might be handy, if you could actually change options. But left, double-left and right clicks on the program icon in the system tray all get no response. The options window popped up only once in the 1.5 years I've had it running (and clicked in hope periodically). As also experienced by another user here. Oh, and there's no newer version at the Asus website, reinstalling it didn't help, the program doesn't get a mention in my laptop's manual, and it has no help file provided with it (at least they're consistent).
    For those who for some strange reason want to keep running USB Charger Plus, the defaults [see attachment] are both options ticked, and Threshold Limit at 25%, if they happen to be what you want maybe it's of some use to you. Though as Hrogi pointed out above, since it charges devices faster, which is harder on batteries, it will wear them out faster.
    Fortunately plugpacks for USB-powered devices are cheap, compact and lightweight, so there's no need to rely on this piece of unreliable Asus crapware while travelling.
    Some nice 'gee whiz' spin from Asus here on what seems to be the program under a previous name (trying to escape a bad rep?). And a user instruction, yay. "To enable the charge function under S3, S4, S5 mode, make sure your... device is well connected to PC under S0 first." Err, yeah, I'll be sure to spend hours googling power modes and fiddling with BIOS settings so this crappy program can still not work properly.
    Just uninstall it. I won't be buying Asus next time round, their sleep/hibernation works poorly on my laptop too, hanging, bluescreening or failing to boot about every second time, which I've learnt since purchase Asus are renowned for. They should !$#% test what they write properly.
    crazyfool33 likes this.
  9. Meaker@Sager
    USB3 is only capable of delivering 900mA of current at 5V, so to charge devices that want more then you have to have a special driver since the spec does not allow the port to deliver more normally. Mostly this only supports apple products though.
    That's the engineering explanation of what is going on but you don't really need to know that. Catzoo gave a pretty adequate explanation.
  10. Clintlgm
    Clintlgm Notebook Consultant
    You don't need it for anything, My right front port charges with my NB turned off. I did not install the Charger Plus after clean installing Win 8.1. Having it installed causes problems with all ports USB 3.0 Asus NB have problems supplying enough power to to all port the charger Plus only make it worse. MHO
    Google Reminder likes this.
