Well boys, I'm done searchin!
Discussion in 'Motorized Vehicles' started by aan310, Jun 30, 2009.
  1. flipfire
    flipfire Moderately Boss
    Congrats to finally getting your car.
    Youlll get used to stick shift after month or so. Its bad to ride the clutch but it cant be helped if your getting used to it.
    You should feel when the clutch is at friction point and engaged, you should feel a small push on the pedal. Try driving a brass button clutch, the pedal will literally kick out when its engaged haha
    When reversing you lightly give it gas (on/off/on/off the pedals...), so yeah reversing does involve a bit of riding the clutch.
  2. aan310
    aan310 Notebook Virtuoso
    OK, thanks guys!
    I'll have to practice with my POS driveway a bit xD
    And next week im taking my great-grandma to church (part of teh deal, every week till she dies) and its really hilly overthere, so that will be some good practice too!
  3. aan310
    Pics are on the first post...
    And ummm, im really scared right now.
    Twice today when i went to back out of my driveway, the car just made a weird sound when letting the clutch out, and diddn't really do anything....
    I hat to shut it off and start it up to get it to work...
    Both times it was reverse....
    What the heck might i ask?
  4. aan310
    Also, ocasionally when going from first to second it kinda "kaberps" (like makes that sound)
    Is that ok?
  5. flipfire
    Does it sound like its crunching?
    Not sure what kaberp is supposed to sound like but it just might be worn 2nd gear synchro's. Whens the last time the transmission oil was changed anyway?
  6. aan310
    Actually, about 2,000 ago with Mobile 1
    And idk, i guess you could call it crunching, grinding, idk what to call it.... it makes the "kablerp" sound though
  7. triturbo
    Do you press the clutch all the way down? Try that, some cars requires to be a little hard on the clutch in order to shift without "kablerp" sounds. Another thing, when you're shifting to R, try to use a little more force and be sure that you've pulled the stick all the way back (if it's standard shift pattern - 1/2 3/4 5/R) :)
  8. flipfire
    Okay try this, When going in reverse, clutch in, move the stick in 3rd or 4th gear first, then into Reverse.
    Reverse dont have synchos so it will and grind sometimes when the engine is spinning too fast.
  9. aan310
    Alright, i'll check those things today and i'll report back!
    As for pressing the clutch all the way, im pretty sure I am, i'll make sure though!
    Ill check back in later after a trip to bestbuy!
  10. Clutch
    Clutch cute and cuddly boys
    I know there is a small problem in Acuras for going to reverse, what I do is pump the clutch once and then put it back in reverse, and when going into reverse there are 2 points or resistance, and if you put in place you are then in reverse, if you do not you get a grinding sound and dont go anywhere.
