Weird "electronic" noise coming from inside my new HP Pavilion G6
Discussion in 'HP' started by BecauseImFD, May 3, 2012.
  1. BecauseImFD
    BecauseImFD Notebook Guru
    Bought an HP Pavilion G6, exchanged it because the old one had a defective screen, this one seems pretty good except whenever there's anything happening on the laptop (game, typing, mouse, something installing), there is this weird, faint "electronic" noise coming from somewhere inside the laptop. When idle, it's quiet, but if I do as much as little as move the mouse, the squeaking noise starts again. It sounds similar to a mouse, I guess. Could something be wrong here?
    I'll put up a sound file soon.
    Also, the fan is always running and pretty audible. When I'm doing something like web browsing, it gets even louder. Is this normal?
  2. mike5026
    mike5026 Notebook Enthusiast
    Sounds like its the hard drive working...Is it really loud? Can always try to replace it and see if it still has the noise.
  3. BecauseImFD
    I can't remember the last laptop sounding like this. Also, isn't the hard drive located under the mousepad? It seems be coming from under the "QWERTY" section of the keyboard. And I've already replaced the laptop once, I want to make sure this is a legit reason for an exchange before going in again.
  4. mike5026
    If its by the QWERTY section I would believe it would be the fan. Yeah the hard drive is located by the touchpad.
  5. BecauseImFD
    Ah, it seems something might be wrong with my fan. Opening Firefox or Cyberlink YouCam makes the fan start to speed up and get very loud in a matter of seconds and for lack of better words, very "electronic" sounds come from around there. Is this normal? I have an i3 Pavilion G6 sitting next to me and it's almost completely silent the entire time doing the same thing. The processor wouldn't have an effect on the build, would it? Can I bring the laptop in for replacement because of this or is there some way to fix this?
  6. davidricardo86
    davidricardo86 Notebook Deity
    It could just be the CPU working. My E425 does the same thing. When I put my ear up to bottom of the laptop, I can hear the CPU ticking, squeaking, hissing, clicking, processing, whatever you want to call it. It happens even when I scroll the mouse wheel. I can also hear my SSD working, same noise slightly more faint, but usually happens during reads and writes. My old Asus U24E did the same thing. It's not the fan because my fan stops spinning at times and I don't have an HDD or CD spinning. Those are totally different sounds.
  7. BecauseImFD
    Well the fan makes a totally different noise and it's obvious it's acting up. I can't get it to down at all. Any little activity causes the fan to go 100%. And that squealing processing noise can be heard up to a meter away from the laptop. Really loud when an intensive program (like a game) is running or when the laptop is booting.
  8. Ichinenjuu
    Ichinenjuu Suffering from Affluenza
    That's CPU whine, no doubt. My Sony VAIO had it so bad, I had to return it. I put in a solid state drive and every time I was in a quiet room I heard this horrible electronic/high-pitched sound coming from where the CPU was and it drove me nuts.
    CPU whine is caused by the Intel processor, not HP. But for some reason, some laptops have it louder than others.
  9. link626
    link626 Asus GL502VM, Lenovo Y580, Asus K53TA
    everything can whine in there, from cpu to mobo. Usually cpu whine is loudest during idle states.
    As a test, go to your control panel Power options and set it to High performance, and see if it still squeaks.
    i have both intel and amd laptops, and returned multiple amd laptops in the past, and they all have it to some extent.
    my intel laptop also has usb noise interference when moving the mouse.
    Any component in there can cause cross interference.
    if it's faint, same as or quieter than the cpu fan, i'd ignore it.
    or you can try your luck and exchange it again, and again. who knows if you'll get a better one
  10. baii
    baii Sone
    Now i read your post again, yes hp fan tend to go weee and get noticeable ~~, caompre to fluuuuu of other laptops I experienced.
    They have a small fan in a small capacity with small exhaust(I think the exhaust is split between top and bottom case thus making more sound then it should ~~)
