WEBCAM PROBLEM SOLVED!! (fingers crossed, here's to hoping...)
Discussion in 'HP' started by DylanBennett, Aug 1, 2007.
  1. nepoediwseye
    nepoediwseye Newbie
    Hey... I tried what you posted up and everything seemed to be going fine, until I directed my webcam to the driver. at the end of the installation it said "device cannot start," and i got a yellow exclamation mark by my webcam, which is now assigned to the acer driver. can you help?? thanks a lot i really appreciate it
  2. flipfire
    flipfire Moderately Boss
    are you sure you have a chicony webcam?
    Rollback to your previous one if the Acer drivers dont work. You can also use the Windows Generic Drivers which is > USB Camera 2.0
  3. cotton_mouth
    cotton_mouth Notebook Geek
    hey guys i have this problem too. i tried installing the hp drivers (which have been updated but not yet advertised).
    after i installed them, am i supposed to like update my webcam in the device manager? if yes, then how? if not, then i just need to install the drivers and that's all? cos i did install the drivers but like nth happened...
  4. DylanBennett
    DylanBennett Notebook Guru
    Installing the drivers is all you should have to do. If that didn't work, then maybe try the Acer drivers.
  5. siljalevanen
    siljalevanen Newbie
    so I did all of those steps.. and then when I got to step 17 it said "windows found driver software for your device but encountered an error while attempting to install it: Acer Crystal Eye webcam, The device cannot start (code 10)"
    Any suggestions? I am soooo desperate right now. :/
  6. siljalevanen
    siljalevanen Newbie
    I had the same problem as them. What do you mean rollback to your previous one? Sorry, I probably sound like an idiot.
  7. SurfWeasel
    SurfWeasel Newbie
    Thank you Dylan! I used that driver and now my camera works. You da man!
    Aloha from Hawaii,
    SurfWeasel
  8. HPguy
    HPguy Notebook Enthusiast
    There's a webcam problem?
  9. vistan00b
    vistan00b Notebook Enthusiast
    thank you!!!!! u r d best!!!
    tried to update the driver w/ the recovery manager but ddnt work but tried dylan's method & everything works perfectly! =D
    100% working on dv6404ca vista home premium!
  10. Kampilan
    Kampilan Newbie
    Ty, works excellent for me to now :)
