Wearing out of LCD hinge question
Discussion in 'Lenovo' started by Sulk, Sep 22, 2006.
  1. Sulk
    Sulk Notebook Guru
    I'm a bit concerned about the lcd hinges on laptops particularly on my Z60m. How long will it take before they wear out?
  2. I'm Confused?
    I'm Confused? Notebook Evangelist
    Thinkpads are generally very sturdy. My old school used to sell some that were over 5 years old and the hinges were still great! I would say a couple hundred thousand openings (that's not as little as you may think)
  3. Dreamer
    Dreamer The Bad Boy
    These hinges are made of steel, you really can't find stronger...
  4. dietcokefiend
    dietcokefiend DietGreenTeaFiend
    All are, some just have plastic covers. It is usually a friction material inside them that wears out though. I would say 3-5 years of use before it starts getting loose or sloppy.
  5. jukem
    jukem Notebook Enthusiast
    After carrying my t60 14in around campus for 2 weeks I can honestly say that pretty much everything on it is very sturdy and well built. Sometimes I forget I even have it in my bag.:D
  6. Dreamer
    Dreamer The Bad Boy
    I would not count on that... there are thousands of different kinds of steel...
  7. Qhs
    Qhs Notebook Evangelist
    Psh, don't worry about it. Ill give it a max of 5 years with massive abuse and 10 years with here and there use.
  8. dietcokefiend
    I wasn't commenting on it further than saying they are all steel.
  9. Dreamer
    Dreamer The Bad Boy
    Sorry I just didn't read it.
    yes they are all steel
  10. paqtrick22
    paqtrick22 Notebook Evangelist
    yep.. all are steel...
    have you looked into the ACER's forum? one guy there had taken pics of his laptop that had cracked hinges (the plastic covering the stell hinges holding the LCD frame).
Similar Threads - Wearing hinge question
  1. abhattal
    508
  2. TheSoftwareGuy
    1,082
