Warning: Some i7-6820HKs and i7-6700HQ have Uneven Core Temps due to Uneven Heatsink
Discussion in 'Hardware Components and Aftermarket Upgrades' started by iunlock, Oct 25, 2016.
Does your 6820HK have cores that are 5c or higher than the others?
  1. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 5c.
    17 vote(s)
    10.2%
  2. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 10c
    24 vote(s)
    14.4%
  3. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 15c
    10 vote(s)
    6.0%
  4. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 20c
    24 vote(s)
    14.4%
  5. My 6820HK core temperatures are all tracking the same, with less than 5c difference.
    20 vote(s)
    12.0%
  6. Yes, I have a 6820HK where Core #3 (4th Core) is 10C cooler than the rest.
    1 vote(s)
    0.6%
  7. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 5c.
    17 vote(s)
    10.2%
  8. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 10c.
    16 vote(s)
    9.6%
  9. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 15c.
    10 vote(s)
    6.0%
  10. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 20c.
    11 vote(s)
    6.6%
  11. My 6700HQ core temperatures are all tracking the same, with less than 5c difference.
    15 vote(s)
    9.0%
  12. Yes, I have a 6700HQ where Core #3 (4th Core) is 10C cooler than the rest.
    3 vote(s)
    1.8%
  1. hmscott
    You were concerned enough to test and verify, which is good, now you know :)
    tilleroftheearth and Papusan like this.
  2. Papusan
    A lot of people are not very concerned now or they don't know. But later down the road, maybe they want to try overclocking for extending the life of the laptop. Then it is all too late bro:no: It's bad enough with soldered i7... But even worse when it does not function as intended.
    hmscott likes this.
  3. saturnotaku
    Just contributing a data point for the benefit of the group, nothing more.
    hmscott likes this.
  4. hmscott
    Thanks!! +rep! :vbthumbsup::hi:
  5. AndersTJ
    AndersTJ Newbie
    Hey all. i just got my 15 R3 6820/1070 Today and after a few Firestrike benchmarks i noticed That some of my core temps are 20c apart
    Core #0 91c
    Core #1 79c
    Core#2 86c
    Core#3 71c
    Package 91c
    Im kinda lost on what i should do here? I guess the only thing there is to do is contact dell and ask for a CPU replacement?.
    Cheers.
    hmscott likes this.
  6. Pallab
    Pallab Notebook Consultant
    Thats a faulty CPU. Repaste will help, but in your case its hardware.
    Send dell a screeenshot and get a replacement.
    hmscott likes this.
  7. AndersTJ
    AndersTJ Newbie
    Would you recommend getting a replacement Laptop or just making them come and replace CPU/Motherboard? and then if possible get them to use my thermal paste.
    hmscott likes this.
  8. Pallab
    They wont replace the CPU/motherboard for you. Even if they did why would you do that when you can get a fresh one.
    20 C differential has to be replaced.
    Repasting the new one will help.
    Papusan and hmscott like this.
  9. AndersTJ
    AndersTJ Newbie
    Ah okay thanks :) It was just because ive been waiting for 3-4 weeks for it to arrive and dont want to wait again for a replacement but if that is the only option i guess that will do.
    hmscott likes this.
  10. villahed94
    villahed94 Notebook Guru
    Even though this is a 6820HK centric thread, I can definetly say Intel's binning for mobile CPUs has been horrible at least since Haswell if not before.
    My laptop has a 4710HQ, which I recently unlocked. And here's what it shows on Heavy Loads
    While on lighter loads I get this:
    A difference like this is most definetly not good and it's clear they are still doing it with "Higher tier" mobile CPUs
    TomJGX, Papusan and hmscott like this.
