Warning: Some i7-6820HKs and i7-6700HQ have Uneven Core Temps due to Uneven Heatsink
Discussion in 'Hardware Components and Aftermarket Upgrades' started by iunlock, Oct 25, 2016.
Does your 6820HK have cores that are 5c or higher than the others?
  1. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 5c.
    14 vote(s)
    9.2%
  2. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 10c
    21 vote(s)
    13.7%
  3. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 15c
    9 vote(s)
    5.9%
  4. Yes, I have a 6820HK that has 1 or more cores with a high temperature differential, greater than 20c
    23 vote(s)
    15.0%
  5. My 6820HK core temperatures are all tracking the same, with less than 5c difference.
    20 vote(s)
    13.1%
  6. Yes, I have a 6820HK where Core #3 (4th Core) is 10C cooler than the rest.
    1 vote(s)
    0.7%
  7. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 5c.
    13 vote(s)
    8.5%
  8. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 10c.
    15 vote(s)
    9.8%
  9. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 15c.
    10 vote(s)
    6.5%
  10. Yes, I have a 6700HQ that has 1 or more cores with a high temp differential, greater than 20c.
    10 vote(s)
    6.5%
  11. My 6700HQ core temperatures are all tracking the same, with less than 5c difference.
    15 vote(s)
    9.8%
  12. Yes, I have a 6700HQ where Core #3 (4th Core) is 10C cooler than the rest.
    3 vote(s)
    2.0%
  1. plee82
    plee82 Notebook Evangelist
    Today is the day![​IMG]
    hmscott and Aman Krishna like this.
  2. plee82
    Ahh!!! 7C difference now. Should I go for round two? Ugh Running prime95 small fft.
    Edit: Holy **** temps not hitting 80c lol
    hmscott likes this.
  3. Papusan
    Papusan BGABOOKS = That sucks!! STAHP! Dont buy FILTH...
    Put load on Gpu simultaneous. I'm sure you will see increased temp and bigger temp difference between the cores. Remember Shared pipes. Use Heaven and not Furmark.
    Oneshot2285 and hmscott like this.
  4. plee82
    Will do. I do notice the HS is slightly elevated on the right side where the thermal pads are.
    hmscott likes this.
  5. plee82
    Tried, stayed at 5-7C difference all the way until 88C on cpu and 79 on gpu and I turn it off.
    hmscott likes this.
  6. plee82
    Ugh should I repaste one more time? I do have a lot of gc extreme left lol.
    hmscott likes this.
  7. Falkentyne
    Falkentyne Notebook Virtuoso
    Are you running DEFAULT prime without AVX and FMT instructions disabled?
    If you are, then no, you don't need to repaste. That's about what you would expect if AVX is enabled.
    If you disabled AVX and FMT (read undoc.txt to find out how and copy the values for it to local.txt, like 3 lines total), then yes you need to repaste.
    Disabling AVX And FMT will drop prime temps by over 10C.
    hmscott likes this.
  8. plee82
    I am running default prime no changes. So is the 7C temp differential acceptable?
    hmscott likes this.
  9. Papusan
    Put Aida64 as the guide and run it 30 min and post temp and results with pict.
    hmscott likes this.
  10. plee82
    I was running prime95 latest version and Heaven at the same time. Lol is Aida heavier than that?
    hmscott likes this.
