Wanna buy a gaming laptop, need help,Thanks
Discussion in 'What Notebook Should I Buy?' started by Allen119966, Jan 14, 2018.
  1. Allen119966
    Allen119966 Notebook Guru
    1) What is your budget?
    Around 1500$
    around 15 inch
    U.S.A
    I don‘t like Msi.
    yes
    Gaming.
    both
    Yes, Leage of legend and most steam games,like dark soul.
    Not sure, but will have it plugged in most of the time.
    Buying online without seeing it is ok.
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Windows.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    Maximum Resolutions.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Either one is fine for me.
    Build Quality and Design
    yes
    As soon as possible, hopefully this month.
    At least 3-5 years.
    Notebook Components
    17) How much hard drive space do you need? Do you want an SSD drive?
    128 SSD is enough.
    No.
    I have no idea about computer stuff at all, just wish to buy something that can handle most games for a while. Some of my friends suggested these options for me but I wish to seek better advise.
    A. MSI GT73
    B. Alienware
    C. Asus 501
    Thanks!
  2. Firefox@yami
    Firefox@yami Notebook Geek
    I don't think you can configure the msi gt73 with 1500$ and alienware is a brand , may be they refer it to the current 15r3/17r4 . I think for 1500$ the clevo p650hs maybe a good choice if you can go with 8gb ram and buy an ssd yourself . I think @woodzstack have some for you
    woodzstack likes this.
  3. don_svetlio
    I'd suggest looking at the Dell Inspiron 7577, Lenovo Legion Y720 or Asus GL503VM
  4. Allen119966
    I really like the looks of Alienware, but I don‘t know why nobody recommend aw, isn’t it a good choice?
  5. don_svetlio
    Alienware machines are generally very well built but you may have to re-apply the thermal paste in some cases since the default application and cooler mountain has a small chance of being poor. Otherwise, they do cost a bit more and usually come with stellar NBD support.
  6. Allen119966
    gigabyte x5,x6 and alienware 15R3,which one is best?thx
  7. don_svetlio
    Check reviews on NoteBookCheck for detailed analysis on the models you've selected. That's the best way to go about it once you've narrowed down your search.
  8. sicily428
    sicily428 Donuts!! :)
    check clevo p650hp6 4-cores mobile cpu +gtx1060
    or clevo n950tp6 6-cores desktop cpu +gtx1060
