W870CU Ripping out my soul! HELP!
Discussion in 'Sager and Clevo' started by DaffyOnLSD, Dec 23, 2010.
  1. DaffyOnLSD
    DaffyOnLSD Notebook Enthusiast
    I've just received my W870 Back from "repairs". the fkers have sent me back a system that now has;
    Flashing Caps/NumLocks, and shuts down after about 15 seconds.
    I've tried removing the battery and booting up, same thing happens, shuts down after boot up.
    Any suggestions?
    I would send it back but they say, "after the new year" ARGH!!
    Just constant problems with this machine whether cosmetic and now this. ARGH help?
  2. JohnnyFlash
    JohnnyFlash Notebook Virtuoso
    That sucks, it sounds like you just got a bum unit. I would video the laptop doing these things and attach it to an email that demanded a replacement.
  3. DaffyOnLSD
    Oh man, your message/solution is depressing me, isn't there anything anyone can suggest to fix this f.ing thing. I waited 1 and a half months to get it back from repairs, now I have to wait again.
    I f.ing hate my second laptop! Dell with media accelerator ARGH it's shlt!
  4. The_Observer
    The_Observer 9262 is the best:)
    Damaged RAM perhaps?
  5. DaffyOnLSD
    Re-sat what I could, ram, hard drive, wasn't sure about wifi, but looked as if it wasn't out of place.
    Anyway rebooted, same problem. Tried different ram sticks one at a time, same thing.
    Although I did try windows memory diagnostics and this is where it got mental, started flashing the caps and num and now BEEPING constantly, until around 22 percent of the diagnostic it cut out. but didn't show any errors.
    So any ideas? Have they broken my ram?
    UPDATE... Not RAM, tried good sticks from a different laptop and same problem.
    blah
  6. JohnnyFlash
    Here's the thing: You have a warranty. You can get a replacement now, I would do that before it's too late; that's the whole point of having it. If you try to fix it yourself, you're going to end up voiding your warranty and then you'll be stuck.
    Sounds to me like your board is bad.
  7. 5150Joker
    5150Joker Tech|Inferno
    Open up the laptop, remove all the heatsinks and make sure they're fastened on there properly with good quality paste. If the system is starting up properly and then beeping/flashing afterwards, it could be shutting down from overheating.
  8. DaffyOnLSD
    The fan for the GPU isn't kicking in, temperature gets to 55 celsius and cuts out.
    I've got a GTX280m, I'm not really familiar with the whole set up.
    But are these connectors in the right places?
    http://nolsd.com/ssp/albums/album-17/lg/P1010831.jpg
    where the missing connector it says VGA next to it.
    or any ideas, thanks a lot.
  9. DaffyOnLSD
    HURAAAH, I put the fan connector into the missing spot VGA, and that seems to be holding the temp at 39C, they must of put it in the wrong hole.
    anyway thanks to everybody that tried to help me out WE DID IT!
    MERRY CHRISTMAS EVERYBODY
  10. Soviet Sunrise
    Soviet Sunrise Notebook Prophet
