w550s/t550 LCD screen replacement - brightness set at max.
Discussion in 'Lenovo' started by giggidy, Apr 5, 2015.
  1. damnation333
    damnation333 Notebook Enthusiast
    Have a look here: https://communities.intel.com/thread/25904?start=165&tstart=0 (see the lower post by Bryce). I have followed that thread since I got my t450. Just checked now and found they put out that new driver 2 weeks ago. Can't wait to try that tonight.
  2. Spearoid
    Spearoid Newbie
    That's pretty nice to see...I've installed this latest driver just now...the exe wouldn't take on my T450s....I had to extract the contents and point device manager to the actual driver file to update the driver.
    Not exactly sure how to take advantage of this potential EDID override allowance in the driver though. The MSDN article is pretty general.
  3. l_i_l
    l_i_l Newbie
    Hey, I just got a used Thinkpad T450s, and the previous owner replaced the stock screen with an LG FHD screen, and I'm getting exactly the same problems as described here. I've read through the thread, and it seems there are two ways of correcting this that were found successful: 1) changing the BIOS whitelist to include the current screen EDID; 2) changing the actual screen EDID to one of the whitelisted values. I'd preferably avoid either of the two options, because 1) it makes future BIOS updates (if any) harder than necessary, and 2) because I don't have the necessary equipment (I think I need a BIOS programmer or Arduino or something, please correct me if I'm wrong).
    It also seems that Intel's latest driver (released about a month ago) for the HD 5500 supposedly allows for overriding the EDID. As previous posters have noted, this gives me a third option, that appears to be still untested, as I wasn't able to find any reports on it.
    I have managed to get one of the whitelisted EDIDs in the registry, generating a .inf file using MonInfo, and then installing the driver using Device Manager. Upon inspection of the registry entries, everything appears to be ok, and the current EDID value matches the desired whitelisted one. However, the problem is not solved at all, I still have no control of the brightness whatsoever. Does anyone have any suggestions?
    If this doesn't work, is flashing the BIOS the only option?
  4. miomi
    miomi Newbie
    @l_i_l
    If your new panel's EEPROM is not write protected, you can just rewrite the new panel EDID. No need hardware equipment, it can be done just with a software like edid-rw.
    I had tried the override inf and registry method, including installing latest intel graphic driver from intel, but no avail.
    Eventually I managed to solve the issue by rewriting the panel's EDID with edid-rw (luckily my panel's eeprom is not write protected).
    Here is the how-to if anyone interested:
    1) You will need linux OS (ubuntu or linux mint for example). If you don't have one in your machine, you can create bootable linux usb flash drive with Rufus or similar tools.
    2) Boot up into the linux, follow the "Installation" part from https://github.com/bulletmark/edid-rw
    3) You will need to find out the panel bus number first. You can do this with command:
    Code:
    $ sudo ./edid-rw 0 | edid-decode
    where the number 0 is the bus number you want to check.
    If you got result like this:
    Code:
    Extracted contents:
    header:          00 ff ff ff ff ff ff 00
    serial number:   30 e4 45 03 00 00 00 00 00 15
    version:         01 04
    basic params:    90 16 0e 78 02
    chroma info:     e8 87 96 5a 55 95 28 22 51 55
    established:     00 00 00
    standard:        01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01
    descriptor 1:    4c 1d 00 ec 50 20 18 30 40 30 57 00 d9 88 00 00 00 1b
    descriptor 2:    16 12 00 80 50 20 16 30 30 20 47 00 d9 88 00 00 00 1b
    descriptor 3:    00 00 00 fe 00 43 33 47 52 4e 80 31 30 31 57 58 31 0a
    descriptor 4:    00 00 00 00 00 00 41 32 a8 00 00 00 00 01 01 0a 20 20
    extensions:      00
    checksum:        9a
    Manufacturer: LGD Model 345 Serial Number 0
    Made week 0 of 2011
    EDID version: 1.4
    then you got the panel bus number. If not, retry by increasing the bus number until you got the number:
    Code:
    $ sudo ./edid-rw 1 | edid-decode
    $ sudo ./edid-rw 2 | edid-decode
    $ sudo ./edid-rw 3 | edid-decode
    In my T450s, the display bus number is 4 (it might vary between machine)
    Note: finding correct bus number is very important. Writing EDID to wrong bus number could destroy other connected hardware on your laptop.
    4) Download the whitelist EDID dump from here (thanks to @t456 for the download links):
    http://forum.notebookreview.com/thr...tness-set-at-max.774101/page-22#post-10271974
    EDID dump of thinkpad X250 FHD IPS panel (LEN40E4 - LP125WF2-SPB2)
    Use the EDID dump file that closely match with your new panel's brand, e.g. if your machine is T450s and the new panel is AUO FHD panel then use "LEN40A3 - B140HAN01.2.bin" or "LEN40A3 - B140HAN01.3.bin", if it's LG FHD panel then use "LEN40A3 - LP140WF3-SPD1.bin". You can rename the dump file into "new_edid.bin".
    Alternatively you can dump the original panel's EDID and rewrite the new panel's EDID with the original panel's EDID. It's only recommended to do this if your original panel and replacement panel has same display resolution & brand, and you haven't swapped the original panel, otherwise just uses the EDID dump file above.
    If you want to dump the original panel's EDID, run this command with your original panel installed:
    Code:
    $ sudo ./edid-rw 4 >original_edid.bin
    (where 4 is the bus number you find from step 3, it might be different in your case)
    Save that original_edid.bin somewhere.
    5) Next, you might want to dump the new panel's EDID for backup. With your new panel had been installed, run this command:
    Code:
    $ sudo ./edid-rw 4 >new_panel_edid_backup.bin
    6) When you're ready, run the command below to rewrite the new panel's EDID to display bus 4 (double check your bus number first before running the command!):
    Code:
    $ sudo ./edid-rw -w 4 <new_edid.bin
    or in case you want to rewrite it with the original EDID dump:
    Code:
    $ sudo ./edid-rw -w 4 <original_edid.bin
    7) Run
    Code:
    $ sudo ./edid-rw 4 | edid-decode
    to check if the EDID is successfully written. If you don't see any change on the EDID data, then it means your new panel's eeprom is write-protected.
    notjaykay, adamchilders and Spearoid like this.
  5. drrossum
    drrossum Notebook Enthusiast
    Good news that you managed to update the EDID.
    I thought EDID write was prevented in the Intel graphics hardware, and that even if you have a dedicated GPU the display is still wired through the Intel graphics chip preventing EDID writes. Did you do the programming on your T450s? That would falsify the theory...
  6. miomi
    miomi Newbie
    The EDID write is done directly to the panel's EEPROM, it's nothing to do with intel graphics chip, it's the panel. As I mentioned before, there is no hardware equipment involved in this case. But if your panel's eeprom is write-protected, then you would need to do the hardware way (using arduino, bus pirate, soldering, or such) to flash the eeprom. Like this for example.
    Spearoid likes this.
  7. adamchilders
    adamchilders Newbie
    Oh my goodness! Thank you so much @miomi ! That worked perfectly for my T450 and the LG panel I installed. If anyone else does this and then installs windows, note that the brightness won't work during the initial boots until the driver is downloaded and installed. The brightness controls will show, but they won't do anything until the driver is in place.
    If you haven't yet, this should totally be posted on the /r/thinkpad subreddit. The T450 is being recommended more and more, and I'm sure this info will save quite a few users.
  8. Spearoid
    Spearoid Newbie
    This is amazing stuff....and I will be giving this a shot here soon. Is there a way to determine if your panel's EEPROM is write-protected? Or do you just try to write to it and see if it fails?
  9. miomi
    miomi Newbie
    Hi, glad to hear it works for you.
    I'm not aware if there are software to check the eeprom's write-protection, so for now you'll need to do the edid write to find out.
  10. christovic
    christovic Newbie
    Hey Everyone!
    Pretty much read this entire forum, and might end up cheaping out and not buying an official FRU for my X250. After all, it's not my main machine and I'd actually quite like to run Linux again after being forced to use Windows for music production!
    However, has anyone been able to get the Intel EDID Override drivers working with a third party panel (assuming that the panel I receive is write protection enabled)? If anyone could shed some light on it, that would be such a great help.
    Thanks,
    Dan
Similar Threads - w550s t550 screen
  1. iphetamine
    323
  2. bellullabob
    271
  3. hiu
    883
