W230SS is beeping and then shut down
Discussion in 'Sager and Clevo' started by razor0601, Jul 11, 2018.
  1. razor0601
    razor0601 Notebook Geek
    I have a Clevo W230SS with the beep and shut down Problem. BIOS was updated, Same thing after that. Also I tried to unplug AC, Battery and BIOS battery. Nothing works.
    Google says it's a Problem with a temp sensor. Could That be?
    Vistar Shook likes this.
  2. Meaker@Sager
    Temp sensor or fan sensor.
  3. razor0601
    Do you know how to fix it?
  4. Meaker@Sager
    What it? You don't know what the issue is yet.
  5. razor0601
    No I don't know. Perhaps someone knows something more.
  6. Meaker@Sager
    Not without looking at it, you need to check fans, see if everything is seated etc.
  7. razor0601
    I replaced the Fan. But not better.
    Yesterday evening it Runs perfect. Today Same Problem
  8. t456
    Keep the 'Sensors' windows of HWiNFO open and quickly check whether it's still showing fan rpms when the first beeps start. Also check for simple temperature overheating, of course.
    The 'no-fan = shutdown' also has a pre-set number of beeps (seconds without a signal), so that too would be a dead giveaway. Have a W230SS as well, so I'll verify the number tomorrow; just have to keep the fan from spinning and see when it shuts off.
  9. razor0601
    Ok trank you
  10. t456
    It's 35 blinks+beeps before it shuts off.
Similar Threads - W230SS beeping shut
  1. TakedaYabu
    228
