W110ER new compatible power brick
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by apexion, Jun 2, 2019.
  1. apexion
    apexion Newbie
    Hi all,
    as the title says, i have recently purchased a W110ER from a friend. the current power brick scares me because the lead that go into the laptop has pulled out and i would like to replace it. as this is very old hardware, i cant seem to find a confirmed workable ac adapter. currently using the generic adapter he was given from Ibuypower. I have been looking this up for a long time now and am sorta at my wits end lol. will this work (questioning because clevo and sager was not listed on page)?
    https://www.newegg.com/p/14R-00PS-00006 Description=coolermaster%20charger&cm_re=coolermaster_charger-_-9SIA1K69854708-_-Product
    thank you for your time.
  2. Meaker@Sager
    5.5mmx2.5mm centre positive barrel type connector (no pin) 19-19.5v matching the ampage of your current brick. Loads of them around, I think the antec universal bricks work very well.
  3. apexion
    apexion Newbie
    @Meaker@Sager i am having good luck with finding chargers that look to meet the required specs however they ar "-c+" and not the other way around and how does one tell what connector is what, was thinking about going universal, is this a safe and good idea? was looking at either the 120W coolermaster (seems hard to find) or a targus 90W. As I am not really familiar with electric current (always scared me a little) can you get the same performance from a 90W as a 120W asking because Ibuypower supplied a 120W when it was sold. And lastly, what does "no pin" mean?
  4. Meaker@Sager
    What's your current brick voltage and amps?
  5. Prema
    Prema Your Freedom, Your Choice
    Been using a Kensington K38080US (90W) and Cooler Master RP-120USNA (120W) with this model.
    You should choose Adapter capacity according to the CPU model in use.
  6. Meaker@Sager
    No pin in the centre of the barrel like Dell adapters have by the way.
