VPCSB no audio after replacement of keyboard
Discussion in 'VAIO / Sony' started by urgiv, May 2, 2013.
  1. urgiv
    urgiv Notebook Consultant
    Hi every one
    I got a problem with mine VPCSB
    I purchased from internet used VPCSB16FG with arabic keyboard
    make long story shor
    I repalced Keyboard for UK laylot
    after start computer audio driver is there and if you click to small speaker looks audio played but no ouput from speakers
    Laptop was opened few times reseated all flat cables and still no analog audio from realtek chip
    no speakers no headphones
    speaker was measured and they have 8oms
    all flat cables measured if pin broken all OK
    is interesing - if I connect hdmi digital audio play OK on TV
    I find in laptop realtek chip witch is located under palm-rest with cart reader but there in not any number like (swx or cnx)
    can you anyone help me with type of board for audio for VPCSB series
    I will so appreciate
    and if please anyone have repair manual as pdf will be a great.
  2. ngvuanh
    ngvuanh Notebook Deity
    Do you see any audio device in Device Manager?
  3. urgiv
    yes audio there as i told no ouput to speaker or headphones
  4. ngvuanh
    I also should check headphones jack because it switches off speakers for headphones and it could be broken too, so there is no sound to headphones or speakers.
    P/N for that board is A-1828-964-A and it names V030 MS/SD DAUGHTER BOARD
  5. urgiv
    THX
    I already exchange this board (btw is IFX-579) and same no sound
    I check all flat cables (measured by multimeter) and still not audio output
    audio icon there and if you play audio level shows but analogue realtek not send to the speakers and headphones.
    I really don't know what can be wrong. I already repaired of 100-ths of VAIO's but this one make me crazy
    probably MBX 237 I dont know
  6. murass
    murass Newbie
    Hey!
    Welcome all here, this is my first post as I am having exactly same problem with my vpcsb! It also drives me mad, tried everything but still no analog sound by realtek! I just wonder did anybody figure it out what's causing this issue?
  7. urgiv
    still nope
    I saw another vpcsb at ebay with exact same issue.
    I decide buy new one with warranty / exchange part by part/ send to sony warranty repair/
    if I will something new I will let you know.
    edit;
    CAN ANYONE HAVE PLEASE BLOCK DIAGRAM OR PDF REPAIR MANUAL
    THX MILION TIMES
  8. murass
    murass Newbie
    My vaio in first place did not see realtek audio card at all, after messing with the yellow dual layer flex that links daughter board with main one the card appeared in the hardware manager but no sound on the output at all. Forgot to mention, the backlite keyboard is also not working, I wonder is it possible to adress this problem directly to sony? Its just so weird, everything has been replaced apart from motherboard - but mobo shouldnt be an issue as the realtek chip is on the daughter board?
  9. urgiv
    try again IFX-579
    and check all pins
  10. plex85
    plex85 Newbie
    and I have just purchased this off ebay.... :) doing so diag work now and hopefully can find something.....
