Volume control and FN key dont work
Discussion in 'Alienware 17 and M17x' started by GP0948, Feb 18, 2013.
  1. GP0948
    GP0948 Newbie
    Just installed windows 7 64-bit on a m17x-r1 and followed the Drivers list off this site. I did not mess with any of the BIOs drivers and the E-SATA drives wouldn't load. Volume works and I can control it from the little speaker icon in the bottom right of the screen; The volume-slider-control just above the keyboard to the left of the power button does not. It lights up when I touch it but does not adjust volume. The blue-tooth, Wifi, etc. buttons to the right of the button work, but the alienware picture-icon-thing that flashes in the upper left of the screen when you use them does not show up.
    The FN key that lets you use the alienware specific alternate F1 - F12 buttons does not work. (i.e. eject, mute, Tpad, etc.)
  2. DDDenniZZZ
    DDDenniZZZ Notebook Deity
    Sounds like the OSD (on screen display) drivers are not installed. I think they need .net framework 3.5 to work as well, so make sure windows updates installed that first then try installing the OSD.
  3. Alienware-L_Porras
    True, you might be missing the OSD, It is listed on drivers and downloads under the applications tag.
