Volume button sound - How to turn down?
Discussion in 'HP' started by Bullit, Nov 14, 2009.
  1. Bullit
    Bullit Notebook Deity
    Hello. Is there any way to turn down the tick tick sound that the volume drag button makes?
  2. mattmjb0188
    mattmjb0188 Notebook Deity
    Yes, go into the bios and disable it :D
  3. sean473
    sean473 Notebook Prophet
    Don't listen to him , he's talking rubbish.. just go and uninstall the Hp quicktouch drivers... they seem to be the ones making the sounds..
  4. mattmjb0188
    OK first off, unistalling quicktouch would also work but disabling it in the bios will not remove the software designed for the buttons. ITs better to disable the noise in the bios.
  5. Th3_uN1Qu3
    Th3_uN1Qu3 Notebook Deity
    Seconded. Why such an option would be put in the BIOS, hell knows, but that's the way it is, and it works.
  6. abaddon4180
    abaddon4180 Notebook Virtuoso
    Clicking on the volume icon in the tray and muting HP MediaSmart in the mixer works fine for me.
  7. Bullit
    Thank you all. In the end i have found a way that just show how the idiots that made HP software are incompetents or evil. After using the quick launch buttons just for luck i clicked in "open volume mixer" and a "Quick Launch Volume" appeared in it , besides the usual "speakers" and "system sounds". I turned down the volume and that was it. Btw the "Quick Launch Volume" just disapeared and i can't find a way to call it . So i don't know the sequence that made it appear.
    Edit: i don't have any HP mediasmart in the Volume Mixer.
