Vista Font Problem
Discussion in 'Dell XPS and Studio XPS' started by ddayzd, Nov 29, 2008.
  1. ddayzd
    ddayzd Notebook Enthusiast
    Okay I'm having a predicament with my windows font. I don't know how or when, but all my fonts became italic and bold and the same time. I found a reg fix that fixed it, but it somehow changed my main font from times new roman to some comic sans looking font.
    I clearly see Times New Roman in my windows font folder, but when I'm in Microsoft Word, it looks like comic sans or something.
    Anyone know what's up with this? Can anyone send me their vista font reg. so I can get this back to normal?
    Here's a picture for reference.
  2. gerryf19
    gerryf19 I am the walrus
    First thing you need to do if you want help is to post the reg file you used to "fix" things.
    Dumping another reg file merge onto a previous reg file merge is a recipe for trouble--Windows gave you a warning for a reason when you did the last one--haphazrdly slapping in more reg files is only going to make more trouble.
  3. ddayzd
    I've found the regedit that I did. Seems like there's alot of segoe UI's.
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes]
    "MS Shell Dlg 2"="Segoe UI"
    "MS Shell Dlg"="Segoe UI"
    "Helv"="Segoe UI"
    "MS Sans Serif 8,10,12,14,18,24"="Segoe UI"
    "MS Serif 8,10,12,14,18,24"="Segoe UI"
    "MS Sans Serif"="Segoe UI"
    "System"="Segoe UI"
    "Microsoft Sans Serif"="Segoe UI"
    "Tahoma"="Segoe UI"
    "MS Serif"="Segoe UI"
    "Times New Roman"="Segoe UI"
    "Times"="Segoe UI"
    "Small Fonts"="Segoe UI"
    "Tms Rmn"="Segoe UI"
    "Arial"="Segoe UI"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
    "Arial (TrueType)"="segoeui.ttf"
    "Arial Italic (TrueType)"="segoeuii.ttf"
    "Arial Bold (TrueType)"="segoeuib.ttf"
    "Arial Bold Italic (TrueType)"="segoeuiz.ttf"
    "Times New Roman (TrueType)"="segoeui.ttf"
    "Times New Roman Italic (TrueType)"="segoeuii.ttf"
    "Times New Roman Bold (TrueType)"="segoeuib.ttf"
    "Times New Roman Bold Italic (TrueType)"="segoeuiz.ttf"
    "Tahoma (TrueType)"="segoeui.ttf"
    "Tahoma Bold (TrueType)"="segoeuib.ttf"
    "Microsoft Sans Serif (TrueType)"="segoeui.ttf"
    "MS Sans Serif 8,10,12,14,18,24 (VGA res)"="segoeui.ttf"
    "MS Serif 8,10,12,14,18,24 (VGA res)"="segoeui.ttf"
    [HKEY_CLASSES_ROOT\Local Settings\Software\Microsoft\Windows\Shell\MuiCache]
    "@themeui.dll,-2037"="{Segoe UI, 8 pt}"
    "@themeui.dll,-2038"="{Segoe UI, 8 pt}"
    "@themeui.dll,-2039"="{Segoe UI, 8 pt}"
    "@themeui.dll,-2040"="{Segoe UI, 8 pt}"
    "@themeui.dll,-2041"="{Segoe UI, 8 pt}"
    "@themeui.dll,-2042"="{Segoe UI, 8 pt}"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontMapper\FamilyDefaults]
    "Swiss"="Segoe UI"
    "Roman"="Segoe UI"
  4. aan310
    aan310 Notebook Virtuoso
    well, that changed all of "arial" "times new Roman" "MS sans Serif" ect... into Segoeui font...
    so, you need to undo the registry file (system restore?)
    and then you will have times new roman again
  5. ddayzd
    Do you mind posting up your font substitute so I can see what to change back?
    I seem to only have 3 system restore points so I don't know which one will change it back to the point where everything is well again.
  6. gerryf19
    Actually, removing the contents of the font substitutes key would solve some of this problem, but that "fix" you did really messed things up.
    Each machine is going to be different so posting my keys could cause trouble if you just try another reg merge.
    Obviously, you should run a system restore on a date before this whole thing went bad.
    That said, here are my corresponding keys
    "Arial (TrueType)"="arial.ttf"
    "Arial Italic (TrueType)"="ariali.ttf"
    "Arial Bold (TrueType)"="arialbd.ttf"
    "Arial Bold Italic (TrueType)"="arialbi.ttf"
    "Batang & BatangChe & Gungsuh & GungsuhChe (TrueType)"="batang.ttc"
    "Courier New (TrueType)"="cour.ttf"
    "Courier New Italic (TrueType)"="couri.ttf"
    "Courier New Bold (TrueType)"="courbd.ttf"
    "Courier New Bold Italic (TrueType)"="courbi.ttf"
    "DaunPenh (TrueType)"="daunpenh.ttf"
    "DokChampa (TrueType)"="dokchamp.ttf"
    "Estrangelo Edessa (TrueType)"="estre.ttf"
    "Euphemia (TrueType)"="euphemia.ttf"
    "Gautami (TrueType)"="gautami.ttf"
    "Gulim & GulimChe & Dotum & DotumChe (TrueType)"="gulim.ttc"
    "Impact (TrueType)"="impact.ttf"
    "Iskoola Pota (TrueType)"="iskpota.ttf"
    "Kalinga (TrueType)"="kalinga.ttf"
    "Kartika (TrueType)"="kartika.ttf"
    "Latha (TrueType)"="latha.ttf"
    "Lucida Console (TrueType)"="lucon.TTF"
    "Malgun Gothic (TrueType)"="malgun.ttf"
    "Malgun Gothic Bold (TrueType)"="malgunbd.ttf"
    "Mangal (TrueType)"="mangal.ttf"
    "Meiryo & Meiryo Italic (TrueType)"="meiryo.ttc"
    "Meiryo Bold & Meiryo Bold Italic (TrueType)"="meiryob.ttc"
    "Microsoft Himalaya (TrueType)"="himalaya.ttf"
    "Microsoft JhengHei (TrueType)"="msjh.ttf"
    "Microsoft JhengHei Bold (TrueType)"="msjhbd.ttf"
    "Microsoft YaHei (TrueType)"="msyh.ttf"
    "Microsoft YaHei Bold (TrueType)"="msyhbd.ttf"
    "MingLiU & PMingLiU & MingLiU_HKSCS (TrueType)"="mingliu.ttc"
    "MingLiU-ExtB & PMingLiU-ExtB & MingLiU_HKSCS-ExtB (TrueType)"="mingliub.ttc"
    "Mongolian Baiti (TrueType)"="monbaiti.ttf"
    "MS Gothic & MS PGothic & MS UI Gothic (TrueType)"="msgothic.ttc"
    "MS Mincho & MS PMincho (TrueType)"="msmincho.ttc"
    "MV Boli (TrueType)"="mvboli.ttf"
    "Nyala (TrueType)"="nyala.TTF"
    "Plantagenet Cherokee (TrueType)"="plantc.ttf"
    "Raavi (TrueType)"="raavi.ttf"
    "Segoe Script (TrueType)"="segoesc.ttf"
    "Segoe Script Bold (TrueType)"="segoescb.ttf"
    "Segoe UI (TrueType)"="segoeui.ttf"
    "Segoe UI Bold (TrueType)"="segoeuib.ttf"
    "Segoe UI Italic (TrueType)"="segoeuii.ttf"
    "Segoe UI Bold Italic (TrueType)"="segoeuiz.ttf"
    "Shruti (TrueType)"="shruti.ttf"
    "SimSun & NSimSun (TrueType)"="simsun.ttc"
    "SimSun-ExtB (TrueType)"="simsunb.ttf"
    "Sylfaen (TrueType)"="sylfaen.ttf"
    "Times New Roman (TrueType)"="times.ttf"
    "Times New Roman Italic (TrueType)"="timesi.ttf"
    "Times New Roman Bold (TrueType)"="timesbd.ttf"
    "Times New Roman Bold Italic (TrueType)"="timesbi.ttf"
    "Tunga (TrueType)"="tunga.ttf"
    "Vrinda (TrueType)"="vrinda.ttf"
    "Microsoft Yi Baiti (TrueType)"="msyi.ttf"
    "Tahoma (TrueType)"="tahoma.ttf"
    "Tahoma Bold (TrueType)"="tahomabd.ttf"
    "Microsoft Sans Serif (TrueType)"="micross.ttf"
    "Angsana New (TrueType)"="angsa.ttf"
    "Angsana New Italic (TrueType)"="angsai.ttf"
    "Angsana New Bold (TrueType)"="angsab.ttf"
    "Angsana New Bold Italic (TrueType)"="angsaz.ttf"
    "Cordia New (TrueType)"="cordia.ttf"
    "Cordia New Italic (TrueType)"="cordiai.ttf"
    "Cordia New Bold (TrueType)"="cordiab.ttf"
    "Cordia New Bold Italic (TrueType)"="cordiaz.ttf"
    "Gisha (TrueType)"="gisha.ttf"
    "Gisha Bold (TrueType)"="gishabd.ttf"
    "Leelawadee (TrueType)"="leelawad.ttf"
    "Leelawadee Bold (TrueType)"="leelawdb.ttf"
    "Microsoft Uighur (TrueType)"="msuighur.ttf"
    "MoolBoran (TrueType)"="moolbor.ttf"
    "Symbol (TrueType)"="symbol.ttf"
    "Wingdings (TrueType)"="wingding.ttf"
    "Modern (All res)"="modern.fon"
    "Roman (All res)"="roman.fon"
    "Script (All res)"="script.fon"
    "Andalus (TrueType)"="andlso.ttf"
    "Arabic Typesetting (TrueType)"="arabtype.ttf"
    "Simplified Arabic (TrueType)"="simpo.ttf"
    "Simplified Arabic Bold (TrueType)"="simpbdo.ttf"
    "Simplified Arabic Fixed (TrueType)"="simpfxo.ttf"
    "Traditional Arabic (TrueType)"="trado.ttf"
    "Traditional Arabic Bold (TrueType)"="tradbdo.ttf"
    "Aharoni Bold (TrueType)"="ahronbd.ttf"
    "David (TrueType)"="david.ttf"
    "David Bold (TrueType)"="davidbd.ttf"
    "FrankRuehl (TrueType)"="frank.ttf"
    "Levenim MT (TrueType)"="lvnm.ttf"
    "Levenim MT Bold (TrueType)"="lvnmbd.ttf"
    "Miriam (TrueType)"="mriam.ttf"
    "Miriam Fixed (TrueType)"="mriamc.ttf"
    "Narkisim (TrueType)"="nrkis.ttf"
    "Rod (TrueType)"="rod.ttf"
    "FangSong (TrueType)"="simfang.ttf"
    "SimHei (TrueType)"="simhei.ttf"
    "KaiTi (TrueType)"="simkai.ttf"
    "AngsanaUPC (TrueType)"="angsau.ttf"
    "AngsanaUPC Italic (TrueType)"="angsaui.ttf"
    "AngsanaUPC Bold (TrueType)"="angsaub.ttf"
    "AngsanaUPC Bold Italic (TrueType)"="angsauz.ttf"
    "Browallia New (TrueType)"="browa.ttf"
    "Browallia New Italic (TrueType)"="browai.ttf"
    "Browallia New Bold (TrueType)"="browab.ttf"
    "Browallia New Bold Italic (TrueType)"="browaz.ttf"
    "BrowalliaUPC (TrueType)"="browau.ttf"
    "BrowalliaUPC Italic (TrueType)"="browaui.ttf"
    "BrowalliaUPC Bold (TrueType)"="browaub.ttf"
    "BrowalliaUPC Bold Italic (TrueType)"="browauz.ttf"
    "CordiaUPC (TrueType)"="CORDIAU.TTF"
    "CordiaUPC Bold (TrueType)"="CORDIAUB.TTF"
    "CordiaUPC Bold Italic (TrueType)"="CORDIAUZ.TTF"
    "CordiaUPC Italic (TrueType)"="CORDIAUI.TTF"
    "DilleniaUPC (TrueType)"="upcdl.ttf"
    "DilleniaUPC Italic (TrueType)"="upcdi.ttf"
    "DilleniaUPC Bold (TrueType)"="upcdb.ttf"
    "DilleniaUPC Bold Italic (TrueType)"="upcdbi.ttf"
    "EucrosiaUPC (TrueType)"="upcel.ttf"
    "EucrosiaUPC Italic (TrueType)"="upcei.ttf"
    "EucrosiaUPC Bold (TrueType)"="upceb.ttf"
    "EucrosiaUPC Bold Italic (TrueType)"="upcebi.ttf"
    "FreesiaUPC (TrueType)"="upcfl.ttf"
    "FreesiaUPC Italic (TrueType)"="upcfi.ttf"
    "FreesiaUPC Bold (TrueType)"="upcfb.ttf"
    "FreesiaUPC Bold Italic (TrueType)"="upcfbi.ttf"
    "IrisUPC (TrueType)"="upcil.ttf"
    "IrisUPC Italic (TrueType)"="upcii.ttf"
    "IrisUPC Bold (TrueType)"="upcib.ttf"
    "IrisUPC Bold Italic (TrueType)"="upcibi.ttf"
    "JasmineUPC (TrueType)"="upcjl.ttf"
    "JasmineUPC Italic (TrueType)"="upcji.ttf"
    "JasmineUPC Bold (TrueType)"="upcjb.ttf"
    "JasmineUPC Bold Italic (TrueType)"="upcjbi.ttf"
    "KodchiangUPC (TrueType)"="upckl.ttf"
    "KodchiangUPC Italic (TrueType)"="upcki.ttf"
    "KodchiangUPC Bold (TrueType)"="upckb.ttf"
    "KodchiangUPC Bold Italic (TrueType)"="upckbi.ttf"
    "LilyUPC (TrueType)"="upcll.ttf"
    "LilyUPC Italic (TrueType)"="upcli.ttf"
    "LilyUPC Bold (TrueType)"="upclb.ttf"
    "LilyUPC Bold Italic (TrueType)"="upclbi.ttf"
    "DFKai-SB (TrueType)"="kaiu.ttf"
    "Lucida Sans Unicode (TrueType)"="l_10646.ttf"
    "Arial Black (TrueType)"="ariblk.ttf"
    "Calibri (TrueType)"="calibri.ttf"
    "Calibri Italic (TrueType)"="calibrii.ttf"
    "Calibri Bold (TrueType)"="calibrib.ttf"
    "Calibri Bold Italic (TrueType)"="calibriz.ttf"
    "Cambria & Cambria Math (TrueType)"="cambria.ttc"
    "Cambria Italic (TrueType)"="cambriai.ttf"
    "Cambria Bold (TrueType)"="cambriab.ttf"
    "Cambria Bold Italic (TrueType)"="cambriaz.ttf"
    "Candara (TrueType)"="candara.ttf"
    "Candara Italic (TrueType)"="candarai.ttf"
    "Candara Bold (TrueType)"="candarab.ttf"
    "Candara Bold Italic (TrueType)"="candaraz.ttf"
    "Comic Sans MS (TrueType)"="comic.ttf"
    "Comic Sans MS Bold (TrueType)"="comicbd.ttf"
    "Consolas (TrueType)"="consola.ttf"
    "Consolas Italic (TrueType)"="consolai.ttf"
    "Consolas Bold (TrueType)"="consolab.ttf"
    "Consolas Bold Italic (TrueType)"="consolaz.ttf"
    "Constantia (TrueType)"="constan.ttf"
    "Constantia Italic (TrueType)"="constani.ttf"
    "Constantia Bold (TrueType)"="constanb.ttf"
    "Constantia Bold Italic (TrueType)"="constanz.ttf"
    "Corbel (TrueType)"="corbel.ttf"
    "Corbel Italic (TrueType)"="corbeli.ttf"
    "Corbel Bold (TrueType)"="corbelb.ttf"
    "Corbel Bold Italic (TrueType)"="corbelz.ttf"
    "Franklin Gothic Medium (TrueType)"="framd.ttf"
    "Franklin Gothic Medium Italic (TrueType)"="framdit.ttf"
    "Georgia (TrueType)"="georgia.ttf"
    "Georgia Italic (TrueType)"="georgiai.ttf"
    "Georgia Bold (TrueType)"="georgiab.ttf"
    "Georgia Bold Italic (TrueType)"="georgiaz.ttf"
    "Palatino Linotype (TrueType)"="pala.ttf"
    "Palatino Linotype Italic (TrueType)"="palai.ttf"
    "Palatino Linotype Bold (TrueType)"="palab.ttf"
    "Palatino Linotype Bold Italic (TrueType)"="palabi.ttf"
    "Segoe Print (TrueType)"="segoepr.ttf"
    "Segoe Print Bold (TrueType)"="segoeprb.ttf"
    "Trebuchet MS (TrueType)"="trebuc.ttf"
    "Trebuchet MS Italic (TrueType)"="trebucit.ttf"
    "Trebuchet MS Bold (TrueType)"="trebucbd.ttf"
    "Trebuchet MS Bold Italic (TrueType)"="trebucbi.ttf"
    "Verdana (TrueType)"="verdana.ttf"
    "Verdana Italic (TrueType)"="verdanai.ttf"
    "Verdana Bold (TrueType)"="verdanab.ttf"
    "Verdana Bold Italic (TrueType)"="verdanaz.ttf"
    "Webdings (TrueType)"="webdings.ttf"
    "Courier 10,12,15"="COURF.FON"
    "MS Serif 8,10,12,14,18,24"="SERIFF.FON"
    "MS Sans Serif 8,10,12,14,18,24"="SSERIFF.FON"
    "Small Fonts"="SMALLF.FON"
    "Haettenschweiler (TrueType)"="HATTEN.TTF"
    "MS Outlook (TrueType)"="OUTLOOK.TTF"
    "Book Antiqua Bold (TrueType)"="ANTQUAB.TTF"
    "Book Antiqua Bold Italic (TrueType)"="ANTQUABI.TTF"
    "Book Antiqua Italic (TrueType)"="ANTQUAI.TTF"
    "Book Antiqua (TrueType)"="BKANT.TTF"
    "Century Gothic (TrueType)"="Gothic.TTF"
    "Century Gothic Bold (TrueType)"="Gothicb.TTF"
    "Century Gothic Bold Italic (TrueType)"="Gothicbi.TTF"
    "Century Gothic Italic (TrueType)"="Gothici.TTF"
    "Bookshelf Symbol 7 (TrueType)"="BSSYM7.TTF"
    "MS Reference Sans Serif (TrueType)"="REFSAN.TTF"
    "MS Reference Specialty (TrueType)"="REFSPCL.TTF"
    "Arial Narrow (TrueType)"="ARIALN.TTF"
    "Arial Narrow Bold (TrueType)"="ARIALNB.TTF"
    "Arial Narrow Bold Italic (TrueType)"="ARIALNBI.TTF"
    "Arial Narrow Italic (TrueType)"="ARIALNI.TTF"
    "Garamond (TrueType)"="GARA.TTF"
    "Garamond Bold (TrueType)"="GARABD.TTF"
    "Garamond Italic (TrueType)"="GARAIT.TTF"
    "Monotype Corsiva (TrueType)"="MTCORSVA.TTF"
    "Agency FB Bold (TrueType)"="AGENCYB.TTF"
    "Agency FB (TrueType)"="AGENCYR.TTF"
    "Arial Rounded MT Bold (TrueType)"="ARLRDBD.TTF"
    "Blackadder ITC (TrueType)"="ITCBlkad.TTF"
    "Bodoni MT Bold (TrueType)"="BOD_B.TTF"
    "Bodoni MT Bold Italic (TrueType)"="BOD_BI.TTF"
    "Bodoni MT Italic (TrueType)"="BOD_I.TTF"
    "Bodoni MT (TrueType)"="BOD_R.TTF"
    "Bodoni MT Black Italic (TrueType)"="BOD_BLAI.TTF"
    "Bodoni MT Black (TrueType)"="BOD_BLAR.TTF"
    "Bodoni MT Condensed Bold (TrueType)"="BOD_CB.TTF"
    "Bodoni MT Condensed Bold Italic (TrueType)"="BOD_CBI.TTF"
    "Bodoni MT Condensed Italic (TrueType)"="BOD_CI.TTF"
    "Bodoni MT Condensed (TrueType)"="BOD_CR.TTF"
    "Bookman Old Style (TrueType)"="BOOKOS.TTF"
    "Bookman Old Style Bold (TrueType)"="BOOKOSB.TTF"
    "Bookman Old Style Bold Italic (TrueType)"="BOOKOSBI.TTF"
    "Bookman Old Style Italic (TrueType)"="BOOKOSI.TTF"
    "Bradley Hand ITC (TrueType)"="BradhITC.TTF"
    "Calisto MT (TrueType)"="CALIST.TTF"
    "Calisto MT Bold (TrueType)"="CALISTB.TTF"
    "Calisto MT Bold Italic (TrueType)"="CALISTBI.TTF"
    "Calisto MT Italic (TrueType)"="CALISTI.TTF"
    "Century Schoolbook (TrueType)"="CENSCBK.TTF"
    "Century Schoolbook Bold (TrueType)"="SCHLBKB.TTF"
    "Century Schoolbook Bold Italic (TrueType)"="SCHLBKBI.TTF"
    "Century Schoolbook Italic (TrueType)"="SCHLBKI.TTF"
    "Copperplate Gothic Bold (TrueType)"="Coprgtb.TTF"
    "Copperplate Gothic Light (TrueType)"="Coprgtl.TTF"
    "Curlz MT (TrueType)"="Curlz___.TTF"
    "Edwardian Script ITC (TrueType)"="ITCEdscr.TTF"
    "Elephant (TrueType)"="ELEPHNT.TTF"
    "Elephant Italic (TrueType)"="ELEPHNTI.TTF"
    "Engravers MT (TrueType)"="Engr.TTF"
    "Eras Bold ITC (TrueType)"="ERASBD.TTF"
    "Eras Demi ITC (TrueType)"="Erasdemi.TTF"
    "Eras Light ITC (TrueType)"="Eraslght.TTF"
    "Eras Medium ITC (TrueType)"="ERASMD.TTF"
    "Felix Titling (TrueType)"="Felixti.TTF"
    "Forte (TrueType)"="FORTE.TTF"
    "Franklin Gothic Book (TrueType)"="Frabk.TTF"
    "Franklin Gothic Book Italic (TrueType)"="Frabkit.TTF"
    "Franklin Gothic Demi (TrueType)"="Fradm.TTF"
    "Franklin Gothic Demi Italic (TrueType)"="Fradmit.TTF"
    "Franklin Gothic Demi Cond (TrueType)"="FRADMCN.TTF"
    "Franklin Gothic Heavy (TrueType)"="FRAHV.TTF"
    "Franklin Gothic Heavy Italic (TrueType)"="FRAHVIT.TTF"
    "Franklin Gothic Medium Cond (TrueType)"="FRAMDCN.TTF"
    "French Script MT (TrueType)"="Frscript.TTF"
    "Gigi (TrueType)"="GIGI.TTF"
    "Gill Sans MT Bold Italic (TrueType)"="GILBI___.TTF"
    "Gill Sans MT Bold (TrueType)"="GILB____.TTF"
    "Gill Sans MT Italic (TrueType)"="GILI____.TTF"
    "Gill Sans MT (TrueType)"="GIL_____.TTF"
    "Gill Sans MT Condensed (TrueType)"="GILC____.TTF"
    "Gill Sans Ultra Bold (TrueType)"="GILSANUB.TTF"
    "Gill Sans Ultra Bold Condensed (TrueType)"="GILLUBCD.TTF"
    "Gill Sans MT Ext Condensed Bold (TrueType)"="GLSNECB.TTF"
    "Gloucester MT Extra Condensed (TrueType)"="GLECB.TTF"
    "Goudy Old Style (TrueType)"="GOUDOS.TTF"
    "Goudy Old Style Bold (TrueType)"="GOUDOSB.TTF"
    "Goudy Old Style Italic (TrueType)"="GOUDOSI.TTF"
    "Goudy Stout (TrueType)"="GOUDYSTO.TTF"
    "Imprint MT Shadow (TrueType)"="IMPRISHA.TTF"
    "Lucida Sans Regular (TrueType)"="Lsans.TTF"
    "Lucida Sans Demibold Roman (TrueType)"="Lsansd.TTF"
    "Lucida Sans Demibold Italic (TrueType)"="Lsansdi.TTF"
    "Lucida Sans Italic (TrueType)"="Lsansi.TTF"
    "Lucida Sans Typewriter Regular (TrueType)"="LTYPE.TTF"
    "Lucida Sans Typewriter Bold (TrueType)"="LTYPEB.TTF"
    "Lucida Sans Typewriter Bold Oblique (TrueType)"="LTYPEBO.TTF"
    "Lucida Sans Typewriter Oblique (TrueType)"="LTYPEO.TTF"
    "Maiandra GD (TrueType)"="Maian.TTF"
    "OCR A Extended (TrueType)"="OCRAExt.ttf"
    "Palace Script MT (TrueType)"="PALSCRI.TTF"
    "Papyrus (TrueType)"="papyrus.ttf"
    "Perpetua Bold Italic (TrueType)"="Perbi___.TTF"
    "Perpetua Bold (TrueType)"="Perb____.TTF"
    "Perpetua Italic (TrueType)"="Peri____.TTF"
    "Perpetua (TrueType)"="Per_____.TTF"
    "Perpetua Titling MT Bold (TrueType)"="PERTIBD.TTF"
    "Perpetua Titling MT Light (TrueType)"="PERTILI.TTF"
    "Pristina (TrueType)"="PRISTINA.TTF"
    "Rage Italic (TrueType)"="RAGE.TTF"
    "Rockwell (TrueType)"="Rock.TTF"
    "Rockwell Bold (TrueType)"="Rockb.TTF"
    "Rockwell Bold Italic (TrueType)"="Rockbi.TTF"
    "Rockwell Italic (TrueType)"="Rocki.TTF"
    "Rockwell Condensed Bold (TrueType)"="ROCCB___.TTF"
    "Rockwell Condensed (TrueType)"="ROCC____.TTF"
    "Rockwell Extra Bold (TrueType)"="Rockeb.TTF"
    "Script MT Bold (TrueType)"="SCRIPTBL.TTF"
    "Tw Cen MT Bold Italic (TrueType)"="TCBI____.TTF"
    "Tw Cen MT Bold (TrueType)"="TCB_____.TTF"
    "Tw Cen MT Condensed (TrueType)"="TCCM____.TTF"
    "Tw Cen MT Condensed Bold (TrueType)"="TCCB____.TTF"
    "Tw Cen MT Condensed Extra Bold (TrueType)"="TCCEB.TTF"
    "Tw Cen MT Italic (TrueType)"="TCMI____.TTF"
    "Tw Cen MT (TrueType)"="TCM_____.TTF"
    "Algerian (TrueType)"="ALGER.TTF"
    "Baskerville Old Face (TrueType)"="BASKVILL.TTF"
    "Bauhaus 93 (TrueType)"="BAUHS93.TTF"
    "Bell MT (TrueType)"="BELL.TTF"
    "Bell MT Bold (TrueType)"="BELLB.TTF"
    "Bell MT Italic (TrueType)"="BELLI.TTF"
    "Berlin Sans FB Bold (TrueType)"="BRLNSB.TTF"
    "Berlin Sans FB Demi Bold (TrueType)"="BRLNSDB.TTF"
    "Berlin Sans FB (TrueType)"="BRLNSR.TTF"
    "Bernard MT Condensed (TrueType)"="BERNHC.TTF"
    "Bodoni MT Poster Compressed (TrueType)"="BOD_PSTC.TTF"
    "Britannic Bold (TrueType)"="BRITANIC.TTF"
    "Broadway (TrueType)"="BROADW.TTF"
    "Brush Script MT Italic (TrueType)"="BRUSHSCI.TTF"
    "Californian FB Bold (TrueType)"="CALIFB.TTF"
    "Californian FB Italic (TrueType)"="CALIFI.TTF"
    "Californian FB (TrueType)"="CALIFR.TTF"
    "Centaur (TrueType)"="CENTAUR.TTF"
    "Chiller (TrueType)"="CHILLER.TTF"
    "Colonna MT (TrueType)"="COLONNA.TTF"
    "Cooper Black (TrueType)"="COOPBL.TTF"
    "Footlight MT Light (TrueType)"="FTLTLT.TTF"
    "Freestyle Script (TrueType)"="FREESCPT.TTF"
    "Harlow Solid Italic (TrueType)"="HARLOWSI.TTF"
    "Harrington (TrueType)"="HARNGTON.TTF"
    "High Tower Text (TrueType)"="HTOWERT.TTF"
    "High Tower Text Italic (TrueType)"="HTOWERTI.TTF"
    "Jokerman (TrueType)"="Jokerman.TTF"
    "Juice ITC (TrueType)"="Juice___.TTF"
    "Kristen ITC (TrueType)"="ITCKrist.TTF"
    "Kunstler Script (TrueType)"="KUNSTLER.TTF"
    "Lucida Bright (TrueType)"="LBRITE.TTF"
    "Lucida Bright Demibold (TrueType)"="LBRITED.TTF"
    "Lucida Bright Demibold Italic (TrueType)"="LBRITEDI.TTF"
    "Lucida Bright Italic (TrueType)"="LBRITEI.TTF"
    "Lucida Calligraphy Italic (TrueType)"="LCALLIG.TTF"
    "Lucida Fax Regular (TrueType)"="LFAX.TTF"
    "Lucida Fax Demibold (TrueType)"="LFAXD.TTF"
    "Lucida Fax Demibold Italic (TrueType)"="LFAXDI.TTF"
    "Lucida Fax Italic (TrueType)"="LFAXI.TTF"
    "Lucida Handwriting Italic (TrueType)"="LHANDW.TTF"
    "Magneto Bold (TrueType)"="MAGNETOB.TTF"
    "Matura MT Script Capitals (TrueType)"="MATURASC.TTF"
    "Mistral (TrueType)"="Mistral.TTF"
    "Modern No. 20 (TrueType)"="MOD20.TTF"
    "Niagara Engraved (TrueType)"="NIAGENG.TTF"
    "Niagara Solid (TrueType)"="NIAGSOL.TTF"
    "Old English Text MT (TrueType)"="OLDENGL.TTF"
    "Onyx (TrueType)"="ONYX.TTF"
    "Parchment (TrueType)"="PARCHM.TTF"
    "Playbill (TrueType)"="PLAYBILL.TTF"
    "Poor Richard (TrueType)"="POORICH.TTF"
    "Ravie (TrueType)"="RAVIE.TTF"
    "Informal Roman (TrueType)"="INFROMAN.TTF"
    "Showcard Gothic (TrueType)"="SHOWG.TTF"
    "Snap ITC (TrueType)"="SNAP____.TTF"
    "Stencil (TrueType)"="STENCIL.TTF"
    "Tempus Sans ITC (TrueType)"="TempsITC.TTF"
    "Viner Hand ITC (TrueType)"="VINERITC.TTF"
    "Vivaldi Italic (TrueType)"="Vivaldii.TTF"
    "Vladimir Script (TrueType)"="VLADIMIR.TTF"
    "Wide Latin (TrueType)"="LATINWD.TTF"
    "MS Mincho (TrueType)"="MSMINCHO.TTF"
    "Edition Regular (TrueType)"="EDITION.TTF"
    "Myriad Web Kursiv (TrueType)"="myriadi.ttf"
    "Myriad Condensed Web Kursiv (TrueType)"="myriadci.ttf"
    "Myriad Condensed Web Standard (TrueType)"="myriadc.ttf"
    "Myriad Web Fett (TrueType)"="myriadb.ttf"
    "Myriad Web Standard (TrueType)"="myriad.ttf"
    "TrajanPro-Regular (OpenType)"="TrajanPro-Regular.otf"
    "TektonPro-Regular (OpenType)"="TektonPro-Regular.otf"
    "TektonPro-Obl (OpenType)"="TektonPro-Obl.otf"
    "TektonPro-BoldObl (OpenType)"="TektonPro-BoldObl.otf"
    "TektonPro-Bold (OpenType)"="TektonPro-Bold.otf"
    "PoplarStd (OpenType)"="PoplarStd.otf"
    "NuevaStd-Regular (OpenType)"="NuevaStd-Regular.otf"
    "NuevaStd-Italic (OpenType)"="NuevaStd-Italic.otf"
    "NuevaStd-BoldItalic (OpenType)"="NuevaStd-BoldItalic.otf"
    "NuevaStd-Bold (OpenType)"="NuevaStd-Bold.otf"
    "MyriadPro-Regular (OpenType)"="MyriadPro-Regular.otf"
    "MyriadPro-It (OpenType)"="MyriadPro-It.otf"
    "MyriadPro-Cond (OpenType)"="MyriadPro-Cond.otf"
    "MyriadPro-BoldIt (OpenType)"="MyriadPro-BoldIt.otf"
    "MyriadPro-Bold (OpenType)"="MyriadPro-Bold.otf"
    "MinionPro-Regular (OpenType)"="MinionPro-Regular.otf"
    "MinionPro-It (OpenType)"="MinionPro-It.otf"
    "MinionPro-BoldIt (OpenType)"="MinionPro-BoldIt.otf"
    "MinionPro-Bold (OpenType)"="MinionPro-Bold.otf"
    "LithosPro-Regular (OpenType)"="LithosPro-Regular.otf"
    "ACaslonPro-Regular (OpenType)"="ACaslonPro-Regular.otf"
    "ACaslonPro-Italic (OpenType)"="ACaslonPro-Italic.otf"
    "ACaslonPro-BoldItalic (OpenType)"="ACaslonPro-BoldItalic.otf"
    "ACaslonPro-Bold (OpenType)"="ACaslonPro-Bold.otf"
    "ADMUI3.fon"="C:\\Program Files\\Adobe\\Photoshop Elements 4.0\\Required\\ADMUI3.fon"
    "Myriad Web (TrueType)"="myriad.ttf"
    "Myriad Web Bold (TrueType)"="myriadb.ttf"
    "Myriad Condensed Web (TrueType)"="myriadc.ttf"
    "Myriad Condensed Web Italic (TrueType)"="myriadci.ttf"
    "Myriad Web Italic (TrueType)"="myriadi.ttf"
    "MS LineDraw (TrueType)"="C:\\Program Files\\All American SportsWare\\Game Time\\linedraw.ttf"
    "OCRATTRegular (TrueType)"="ocr_atrg.ttf"
    "New (TrueType)"="18cents.ttf"
    "Alien Encounters (TrueType)"="aliee13.ttf"
    "Almonte Snow (TrueType)"="almosnow.ttf"
    "Asimov (TrueType)"="asimov.ttf"
    "Baby Kruffy (TrueType)"="babyk___.ttf"
    "BN Jinx (TrueType)"="bnjinx.ttf"
    "BN Machine (TrueType)"="bnmachine.ttf"
    "Bobcat (TrueType)"="bobcat.ttf"
    "Candles (TrueType)"="candles_.ttf"
    "Chinyen Normal (TrueType)"="chinyen.ttf"
    "Cracked Johnnie (TrueType)"="cracj___.ttf"
    "Creepygirl (TrueType)"="creerg__.ttf"
    "Digifit (TrueType)"="digifit.ttf"
    "Distant Galaxy (TrueType)"="distant galaxy 2.ttf"
    "Ethnocentric (TrueType)"="ethnocen.ttf"
    "Fingerpop (TrueType)"="fingerpop2.ttf"
    "Flubber (TrueType)"="flubber.ttf"
    "Gazzarelli (TrueType)"="gazzarelli.ttf"
    "Good Times (TrueType)"="goodtime.ttf"
    "Hand Me Down S -BRK- (TrueType)"="handmeds.ttf"
    "Heavy Heap (TrueType)"="heavyhea2.ttf"
    "Hollywood Hills (TrueType)"="hollh___.ttf"
    "Induction (TrueType)"="inductio.ttf"
    "LittleLordFontleroy (TrueType)"="littlelo.ttf"
    "LetterOMatic! (TrueType)"="ltromatic.ttf"
    "Mael (TrueType)"="mael____.ttf"
    "PR Celtic Narrow (TrueType)"="narrow.ttf"
    "Nasalization (TrueType)"="nasaliza.ttf"
    "Neon Lights (TrueType)"="neon2.ttf"
    "Parry Hotter (TrueType)"="parryhotter.ttf"
    "SF Movie Poster (TrueType)"="sf movie poster2.ttf"
    "Snowdrift (TrueType)"="snowdrft.ttf"
    "Terminator Two (TrueType)"="terminat.ttf"
    "Woodcut (TrueType)"="woodcut.ttf"
    "Overexposed (TrueType)"="xfiles.ttf"
    "Year supply of fairy cakes (TrueType)"="yearsupplyoffairycakes.ttf"
    "Digital (TrueType)"="digital.ttf"
    "hooge 05_55 Cyr2 (TrueType)"="hoog0555_cyr.ttf"
    "Berling Antiqua (TrueType)"="berling.ttf"
    "Berling Antiqua Bold (TrueType)"="berlingb.ttf"
    "Berling Antiqua Italic (TrueType)"="berlingi.ttf"
    "Berling Antiqua Bold Italic (TrueType)"="berlingz.ttf"
    "Bookdings (TrueType)"="bkdings.ttf"
    "Frutiger Linotype Bold (TrueType)"="frutbd.ttf"
    "Frutiger Linotype (TrueType)"="frutiger.ttf"
    "Frutiger Linotype Italic (TrueType)"="frutit.ttf"
    "Frutiger Linotype Bold Italic (TrueType)"="frutz.ttf"
    "Alaska (TrueType)"="BRALARC0.TTF"
    "Alaska Extrabold (TrueType)"="BRALABC0.TTF"
    "Century (TrueType)"="CENTURY.TTF"
    "Wingdings 2 (TrueType)"="WINGDNG2.TTF"
    "Wingdings 3 (TrueType)"="WINGDNG3.TTF"
    "Arial Unicode MS (TrueType)"="ARIALUNI.TTF"
    "Holiday-India (TrueType)"="Holiday.ttf"
    "MT Extra (TrueType)"="C:\\Program Files\\Common Files\\Microsoft Shared\\EQUATION\\MTEXTRA.TTF"
    "Typewriter Oldstyle (TrueType)"="typeo___.ttf"
    "Thickhead (TrueType)"="Thickhea.ttf"
    "Computerfont Regular (TrueType)"="Computerfont.ttf"
    "Black Chancery (TrueType)"="Chancery.ttf"
    "Alfredo's Dance (TrueType)"="Alfredo.ttf"
    "Signature Regular (TrueType)"="Signatur.ttf"
    "Castellar (TrueType)"="CASTELAR_0.TTF"
    "Aero Extended Hollow (TrueType)"="Aero Extended Hollow.ttf"
    "Engravers MT Bold (TrueType)"="Engrb.TTF"
    "Eurostile Bold (TrueType)"="Eurostib.TTF"
    "Eurostile (TrueType)"="Eurosti.TTF"
    "Maiandra GD Italic (TrueType)"="Maiandit.TTF"
    "Maiandra GD Demi Bold (TrueType)"="Maiandb.TTF"
    "Matisse ITC (TrueType)"="matisse_.ttf"
    "MS Reference 1 (TrueType)"="MSREF1.TTF"
    "MS Reference 2 (TrueType)"="MSREF2.TTF"
    "MS Reference Sans Serif Italic (TrueType)"="REFSANI.TTF"
    "MS Reference Sans Serif Bold (TrueType)"="REFSANB.TTF"
    "MS Reference Sans Serif Bold Italic (TrueType)"="REFSANBI.TTF"
    "Arabic Transparent"="Arial"
    "Arabic Transparent Bold"="Arial Bold"
    "Arabic Transparent,0"="Arial,178"
    "Arabic Transparent Bold,0"="Arial Bold,178"
    "Helvetica"="Arial"
    "Arial Baltic,186"="Arial,186"
    "Arial CE,238"="Arial,238"
    "Arial CYR,204"="Arial,204"
    "Arial Greek,161"="Arial,161"
    "Arial TUR,162"="Arial,162"
    "Courier New Baltic,186"="Courier New,186"
    "Courier New CE,238"="Courier New,238"
    "Courier New CYR,204"="Courier New,204"
    "Courier New Greek,161"="Courier New,161"
    "Courier New TUR,162"="Courier New,162"
    "Times"="Times New Roman"
    "Times New Roman Baltic,186"="Times New Roman,186"
    "Times New Roman CE,238"="Times New Roman,238"
    "Times New Roman CYR,204"="Times New Roman,204"
    "Times New Roman Greek,161"="Times New Roman,161"
    "Times New Roman TUR,162"="Times New Roman,162"
    "MS Shell Dlg 2"="Tahoma"
    "MS Shell Dlg"="Microsoft Sans Serif"
    "Helv"="MS Sans Serif"
    "Tms Rmn"="MS Serif"
    "David Transparent"="David"
    "Miriam Transparent"="Miriam"
    "Fixed Miriam Transparent"="Miriam Fixed"
    "Rod Transparent"="Rod"
    "FangSong_GB2312"="FangSong"
    "KaiTi_GB2312"="KaiTi"
    @="Arial"
    "Swiss"="Arial"
    "Modern"="Courier New"
    "Decorative"="Impact"
    "Script"="Segoe Script"
    "Roman"="Times New Roman"
